2008 RZT42..why do I need to replace the drive belt every other year1?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #1
pennyanguy
Kubota/ ariens
2008 RZT-42... good runner, I am not the original owner but its only got about 800 hours on it. I have had it for about 8 years now...
every other year I find I have to replaced the drive belt because the LH drive begins to loose power and begins clicking...I can still drive it...it just looses power on turns and fades a little to the left on straightaways... change the belt and all is OK for a while. My yard is not very large, about 200 X 200, and being in NY I dont think I mow more then 15-20 times a year... So why do these belts not last...or is it something else I should look for (pulley, spring...)
I have searched the DB and can't find any recommendations for drive belt replacement intervals... is there any recommendation?
Anyone know of a better quality belt then the cub cadet replacement?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #2
I don't think that the Cub belt is cogged, correct? Toro uses some cogged belts and I always thought that was a good idea. What number are you using?
The part # I have is 754-04043B Its supposed to be 1/2" x 57.7".... I have been careful to get the MTD belt because some other makes online show the size as 58"...It is not cogged. Any ideas?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #4
An AX56 is cogged @ 58"
Do you think the cogged belt would last longer? the originals never seem to break, they just seem to stretch rather quickly...why would a cogged belt not stretch as easily?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #6
Try changing the springs. The pulleys and idler must be good or your belt would be chewed up.
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #7
If the belt I referenced is better for you, I dunno. Cheap to try. It would depend on a few different factors. My thoughts were that possibly the cogged belt would grip those hydro pulleys better. I have less lazy left hand hydros on the Toro's than the MTD's. The cogged belt may be the reason. Just a thought.
Thats as good an answer as any...I'm game... Got one on order already!:laughing:
Will let you know how it works out... Thanks for your expertise!
OK, got both the cogged and factory belt in and ..... the cogged belt is 1/2" longer... way too long...I did install it and it would not tighten up enough with the idler pulley..., so I pulled it off and put the factory one on an ...back to mowing...at least for now.
What I did also do was replace the idler spring...belt seems to be tighter now then I recall it ever being before so we shall see.
Also...I did find the possible reason for my belts going bad so often...the engine drive pulley looks like someone used a crowbar to get a previous belt on and off, one lip is bent and twisted... the belt still goes around ok...but I bet thats why they are getting beaten up sooo easily... next time around i will be changing that pulley...which looks like its gonna take a lot for work then just a belt....ohh well
Theres the update
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #10
Good catch. Too bad on cogged belt length though. Next new belt you get exact measurements for a comparison. Hopefully the drive pulley will slide off the shaft for you. About 2 out of 3 MTD's don't unfortunately.
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
2006 VOLVO VHD TANDEM AXLE REAR DISCHARGE CONCRETE MIXER (A56129)
2006 VOLVO VHD...
1983 Case 580D (A47477)
1983 Case 580D...
2018 John Deere 325G (A47477)
2018 John Deere...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
