2008 RZT42..why do I need to replace the drive belt every other year1?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #1
pennyanguy
Kubota/ ariens
2008 RZT-42... good runner, I am not the original owner but its only got about 800 hours on it. I have had it for about 8 years now...
every other year I find I have to replaced the drive belt because the LH drive begins to loose power and begins clicking...I can still drive it...it just looses power on turns and fades a little to the left on straightaways... change the belt and all is OK for a while. My yard is not very large, about 200 X 200, and being in NY I dont think I mow more then 15-20 times a year... So why do these belts not last...or is it something else I should look for (pulley, spring...)
I have searched the DB and can't find any recommendations for drive belt replacement intervals... is there any recommendation?
Anyone know of a better quality belt then the cub cadet replacement?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #2
I don't think that the Cub belt is cogged, correct? Toro uses some cogged belts and I always thought that was a good idea. What number are you using?
The part # I have is 754-04043B Its supposed to be 1/2" x 57.7".... I have been careful to get the MTD belt because some other makes online show the size as 58"...It is not cogged. Any ideas?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #4
An AX56 is cogged @ 58"
Do you think the cogged belt would last longer? the originals never seem to break, they just seem to stretch rather quickly...why would a cogged belt not stretch as easily?
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #6
Try changing the springs. The pulleys and idler must be good or your belt would be chewed up.
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #7
If the belt I referenced is better for you, I dunno. Cheap to try. It would depend on a few different factors. My thoughts were that possibly the cogged belt would grip those hydro pulleys better. I have less lazy left hand hydros on the Toro's than the MTD's. The cogged belt may be the reason. Just a thought.
Thats as good an answer as any...I'm game... Got one on order already!:laughing:
Will let you know how it works out... Thanks for your expertise!
OK, got both the cogged and factory belt in and ..... the cogged belt is 1/2" longer... way too long...I did install it and it would not tighten up enough with the idler pulley..., so I pulled it off and put the factory one on an ...back to mowing...at least for now.
What I did also do was replace the idler spring...belt seems to be tighter now then I recall it ever being before so we shall see.
Also...I did find the possible reason for my belts going bad so often...the engine drive pulley looks like someone used a crowbar to get a previous belt on and off, one lip is bent and twisted... the belt still goes around ok...but I bet thats why they are getting beaten up sooo easily... next time around i will be changing that pulley...which looks like its gonna take a lot for work then just a belt....ohh well
Theres the update
   / 2008 RZT42..why do I need to replace the drive belt every other year1? #10
Good catch. Too bad on cogged belt length though. Next new belt you get exact measurements for a comparison. Hopefully the drive pulley will slide off the shaft for you. About 2 out of 3 MTD's don't unfortunately.
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
1996 Ford F Series Distribution Truck (A47477)
1996 Ford F Series...
Giyi Mini Land Leveler (A53316)
Giyi Mini Land...
2014 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2014 Ford F-350...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
