Sears Welder
   / Sears Welder #11
   / Sears Welder #12
I really like that Craftsman, but then I have a soft spot for older Made in USA and Canada transformer welders.
   / Sears Welder #16
Those welders are quite a sight.
I thought I bought some heavy 12 foot racking beams. How deep are those and what are they rated for?
   / Sears Welder #17
Those welders are quite a sight. You just need a steel table in the middle and sub yourself out to the CIA for an interrogation facility. Just seeing those, would make someone start talking! lol
   / Sears Welder #18
Maybe something like this, with a chair?
The pallet racking is 42” deep. I can’t recall the load rating on those. I would normally ask Rick my retired pallet rack guy when he drops by for coffee but sadly he’s dealing with chemo issues at the moment.
   / Sears Welder #19
I just switched from 36" to 42" racking, not knowing that I had 36" and 42" works better for my driveshed. But I was reffering to the height and rating of the beams?
The tough customers might work themselves right up to the BIG motor driven welder!
You could also forgo the welders and just have a wicker chair.
   / Sears Welder #20
The stepped load beams are a little under 6” tall and 2.75 in wide.
The manufacturer is North American Steel and I’m uncertain of the load rating for a beam with those dimensions for a 12 foot span.
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2005 Ford Escape XLS SUV (A48082)
2005 Ford Escape...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
