Tiller sub-compact rear rototiller: forward vs reverse tine direction
/ sub-compact rear rototiller: forward vs reverse tine direction #1
cfb
Cleveland, Ohio
1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
Hello,
I've not heard of reverse tiller direction until I started looking for a sub-compact. At least in the Kubota make, I'm uncertain between the BX2380 and B2301.
This is what I've read here and/or heard by Messick's and others:
a. a reverse direction takes more HP
b. a reverse is better for established gardens - provides a nice finish at the end
c. reverse is more aggressive, leaves a deeper, cleaner seedbed, in fewer passes
d. forward is ideal when require shallow till depth
c. Kubota dealer told me that all tiller manufacturers are interchangeable between tractor brands as long as it is with a Cat I hitch. I have to find out yet the difference between a full Cat I and a limited Cat I.
I have an established garden, so only its a maybe if I'll till up new ground which I may if making swales. Even though I've been improving the soil for 30 years, it is far from soft loam. I plant a cover crop each winter.
I have a old ford 16HP diesel lawn/garden (mow/plow snow/rototill) that I'm replacing - very difficult for parts now) that did a pretty nice job of tilling and when soil is right, I get a nice smooth planting bed. However, in the past - not sure if that is why I replace the shaft end bearings, I added a sand sack to try and penetrate a bit deeper. I have a similar age 448 Ingersoll. It tills nice and penetrates for some reason faster than the Ford. Both are forward directional.
Not sure if there is a price difference between the two directions
Just wondering from experience what you all think of these two types of directional tillers. I suppose are tillers either one or the other or does someone offer one that does both?
I guess they make tillers to fit the size tractor, so what I'm looking at is around the 23 HP range give or take 1-2HP perhaps.
Kubota says they own Land Pride. But the SRT 48: that the Massey dealer recommended as I think it was a 1/2 inch deeper depth, which I'm also interested in. Currently, I guess I never measured, but I only go deeper if I first spaded an area. My plot is about 60"x60".
It is probably one of those decision where I'll be happy whatever I get, but wanted to be as informed as possible.
thanks
/ sub-compact rear rototiller: forward vs reverse tine direction #2
The reverse rotation is like tilling twice in one pass! We don't have to much ground in our area that doesn't have stones so we don't sell to many reverse tine tillers.
/ sub-compact rear rototiller: forward vs reverse tine direction #3
The biggest thing I heard was the HP draw and traction. With the reverse tiller, the tines are trying to pull the tractor backwards, so your tires will dig in more, or slip based on tires and weight. I never used a reverse, I have a KK 60", and has done everything I've needed it too. I do more landscaping tho. I don't do a yearly garden, but have done it for the neighbors, and seemed to work great.
/ sub-compact rear rototiller: forward vs reverse tine direction #4
Reverse rotation does a better job in one pass, but it really doesn't like rocks. Forward rotation, go slower or make 2 passes, wind up with a similar/identical result. IMHO, the question of rotation direction comes down to "do you have a lot of rocks". If yes, forward rotation, if no, either forward or reverse, but lean towards reverse.
/ sub-compact rear rototiller: forward vs reverse tine direction #5
Here we have a lot of tree roots and that is worse than rocks. I have seen reverse tillers actually stall a tractor when caught on a large root.
/ sub-compact rear rototiller: forward vs reverse tine direction #6
It could also come down to seat time. Some of us like seat time and don't mind taking extra passes though the garden, so we'd lean towards forward rotation. Then there's those other things, power, traction, rocks, etc.
I have a quarry in my garden and I like seat time, so it's forward for me.
Chris
Thanks all for your comments. I believe I get the idea now of the reverse digging in. I borrowed my Father-in-law's little cultivator and even my dad's little Mantis and when I pulled backwards on them, they dug in further. I don't have rocks or roots in my current plot. And I don't mind the seat time. Maybe a newer tractor with more HP will make the job easier or faster. Currently, I make a single pass with the total width of the tiller to bust up the winter cover crop or after harvest, but then it goes better when I just take half passes, have on the previous pass and half on the next row, so to speak. When the soil moisture is just right, I get a good seed bed. I have not compared price yet between the two.
I'd be curious if any wanted to share what models tiller you have with your compact - and if any are able to adjust over, I guess called offset if using a narrower than wheels tiller so that just one side is covered in a pass. thanks again. cfb
/ sub-compact rear rototiller: forward vs reverse tine direction #8
I have had both types of tillers on my garden tractors.
The rear tine direction is best for really hard ground and busting sod for the first time.
The forward tine direction is best for incorporating mulch.... If you want to put several inches of leaves/grass clippings/etc. in the garden and till them in, this is the one you want.
/ sub-compact rear rototiller: forward vs reverse tine direction #9
I have a BX 2380 with reverse tiller Land Pride RTR1250. I had the same one on my L3800, but that was a foot wider. In any case, I love my tiller. Does a great job for me. Tractor has plenty of HP to handle and frankly I think my BX could have used my RTR1260 had I just kept it. Would have been heavier, etc, but I do think it could have handled it. Handles the 1250 with no issues. Tills deep and very nice finish.
Anyway, do not buy the landpride RTR0550. The 0550 is terrible. Short tines, not as deep. Shear pins break easily. Spend more time putting in new shear pins than tilling. My brother bought that one with his BX at first and regretted it until the day he took it back to the dealer.
/ sub-compact rear rototiller: forward vs reverse tine direction #10
Just wondering what you think of these two types of directional tillers. I suppose are tillers either one or the other or does someone offer one that does both?
It is one of those decision where I'll be happy whatever I get, but wanted to be as informed as possible.
Reverse direction tillers must be constructed considerably heavier than forward direction tillers due to stress of implement pulling against the tractor. Reverse direction tillers cost considerably more than forward direction tillers.
For your 60' X 60' kitchen garden I opine that forward direction internal chain drive would be as satisfactory as internal gear drive. I will also guesstimate that forward direction tillers are 95% of the market; reverse direction and bi-direction tillers combined 5% of the market.
You should research C-shaped rototiller tines versus L-shaped rototiller tines.
LINK: https://www.tractorbynet.com/forums...s-different.html?highlight=C-TINES+VS+L+TINES
/ sub-compact rear rototiller: forward vs reverse tine direction #11
My 48" 3pt tiller is forward rotating.
My walk behind Troy Bilt is a CRT, Counter Rotating Tines Tiller, one set forward, one set reverse.
Is there such a thing as a counter rotating tine 3 pt tiller?
Thanks David for this specific info. The 2380 was what I first looked at and I think quoted to me by the dealer. I'll have to check what tiller he included with the quote. I'm sure it was a forward one though.
thanks for this comment. Leaves, grass, straw, manure have been what I do till in each year, well, not manure each year. Looks like in your picture you have maybe a single bottom plow? I saw a youtube with a Kubota BX trying out a Land Shark plow which piqued my interest as I have an old one from a Sears tractor. I had discs with that tractor two that I've used occasionally, so maybe I can go that route. Just fun to check out these possibilities before the need is more crucial.
thanks for the input. replacing tines is something I want to consider if possible, but figured with this larger tractor and tiller, they probably will be more common place down the road, whereas my Ford, well, that is what started me looking more intently as their tines are no longer available - just waited a few years too long - and could not find any on line that matched the size/shape/bolt holes. I'm thinking forward too right now, especially if reverses are considerably more expensive. Maybe the tines are opposite too, and down the road for the next person, forward may be the way to go. I'll check out the link you shared.
Kioti: with the CS2510, the RTR0550. I didn't even realize the reverse style was quoted. It was the first brand I looked at. Didn't even know at the time there was a reverse style.
Kubota: with the BX2380, the RTA1250
The Kubota dealer gave me a LandPride catalog. Both tillers show a 6 1/2" till depth. Both have 4, C shape tines per flange.
Yanmar: either the 221 or 324, matched me with a Rhino REB60: It uses the L-shaped tines and have 6 per flange and lists a till depth of 7 1/2 "
Massey: not sure I'm considering any more, matched me with a Rhino, SRT-48". I don't have specs on it, but see now it is considered as light duty.
Deere: with 1025R matched me with a 647 tiller. I do not have specs on it yet.
I want to consider King Kutter as many ave praised it and I think they make the tillers for Rural King.
/ sub-compact rear rototiller: forward vs reverse tine direction #16
Good, then they must have made changes in the last couple years. The tines on the 0550 were 2" shorter previously and it did not have a slip clutch. Do yourself a favor and make sure you get a slip clutch. You won't want to be replacing broken shear pins instead of working.
/ sub-compact rear rototiller: forward vs reverse tine direction #17
Maybe a used one?
Find a close import used tractor dealer who buys tractors by the container load. Lots of these come with a rototiller on them and gets taken off.
I bought mine for $650.00 (Yanmar) was in great condition and does a amazing job. Very pleased. They come in all widths.
Use it for a year.... if you dont like it sell it for what you paid for it.
