Erratic PTO rotation
/ Erratic PTO rotation #1
patmac3
Devon UK
Kioti CK2810 HST
Hi All,
I hope that members may give me an idea of what I need to check out to see if I have a problem here.
Im using a 5 foot finishing mower on the Kioti CK2810 HST.
I bought the tractor a year ago with 50 hours on clock and a warranty that expired in Dec18.
Shortly after buying, the seal at the pto shaft on the tractor was replaced due to slight seepage of oil. Im now up to 100 hours mowing an undulating grass field of 3 acres.
Ive started to notice that after Ive been mowing for say 30 mins the pto shaft intermittently slows.
The deck keeps cutting and the engine revs stay up and travel speed stays constant.
If I disengage and reengage the pto, rotation may start normally or may again rotate slowly.
At present if I see the pto rotating erratically I stop mowing and leave the tractor to cool right down.
Then if I restart all is well until things warm up.
The gears and pto engage and disengage cleanly with no grinding. I only use the clutch for changing gear or engaging/ disengaging pto.
There is no evidence of any fluid leaks.
Whilst the transmission dipstick is a pain to read the level looks satisfactory.
I spoke to my dealer yesterday who said it may be - the clutch slipping when warm ( but engine revs stay up)
or the belt on the mower slipping . The mowing deck was bought new so has done 50 hours.
Ive checked for play on the clutch pedal and it does seem a little restricted so I have asked the dealer to sort that.
As there are so many experienced users on the forum I thought that I would ask for some ideas on diagnosis from others who may have seen this same problem. It will certainly be helpful in my discussions with the dealer!
Many thanks
Pat
/ Erratic PTO rotation #2
I'd have the dealer put the tractor on a dynamometer under a full load and watch the PTO rpms. That will tell you a lot. Sounds like the PTO clutch (most likely hydraulic) is slipping internally.
/ Erratic PTO rotation #3
Hi All,
....Ive started to notice that after Ive been mowing for say 30 mins the pto shaft intermittently slows.
If the PTO clutch is slipping the mower rpm's will vary just as erratically as the PTO shaft. Can you hear the mower's rpms (blades, air, etc..) vary with the PTO shaft rpms?
What is confusing is you say the deck keeps cutting.
Excuse this question, but is it just the PTO guard (over the shaft) that you're looking at spinning/not spinning erratically and not the shaft inside it? Does the pto coupling that attaches to tractors PTO shaft vary erratically?
/ Erratic PTO rotation #4
I'd hook up another implement that uses the PTO and see how it behaves.
/ Erratic PTO rotation #5
Is there a slip clutch PTO shaft to the mower? Check it's adjustment, it may be slipping.
The CK2810 HST has a live PTO and a clutch between engine and the PTO and transmission. Not a separate PTO clutch. If the clutch is slipping you'd notice that your ground speed is slowing down. If that clutch is slipping you need to fix it right away as replacing it requires splitting the tractor.
/ Erratic PTO rotation #6
Is there a slip clutch PTO shaft to the mower? Check it's adjustment, it may be slipping....
Not sure OP's background, so I'll state the obvious:
This is a possibility if the slip clutch is at the tractor end of the PTO shaft near where it connects to tractor.
However, if the slip clutch it at the mower end of the shaft, he shouldn't see the pto shaft intermittently slow.
/ Erratic PTO rotation #7
Yep, thanks for clarifying.
Also note that the PTO shaft should have a plastic shield on it. If the shield is not clipped to the tractor with the supplied chain it can rotate with the shaft inside. Sometimes only one end has a chain and the other half will rotate. They often rotate more or less depending on the small amount of friction between the shield and the shaft. That's nothing to worry about.
If the PTO shaft itself is slowing a lot you should feel the mower losing performance and see it in how it cuts.
Many thanks for all comments - they are very helpful. It is the actual pto shaft at the ‘connected to mower end ‘ that I see slowing in rotation. I haven’t stepped off the tractor and looked at the pto rotation at the tractor connection end so will do that.
Eric is correct that it is a live pto with clutch between engine and pto which is why it seems odd that the engine revs don’t vary.
The shield on the pto is only clipped at the tractor. The shield covers about 2/3 to 3/4 of the length of the pto shaft so there is a clear bit of uncovered shaft on view at the mower end. This is the end I can see varying speed of rotation.
Sometimes the slowing is quite substantial - could friction bring the speed of rotation down like this?
Luckily the dealer is only 5 miles away and his mobile mechanic is coming out tomorrow so I have lots of questions I can ask and will report back to the forum with his findings.
/ Erratic PTO rotation #9
Does your mower have a slip clutch?
Can you post a pic with the entire pto shaft from tractor to mower gear box in the pic? From the side, so we can see it?
/ Erratic PTO rotation #10
The shield is supposed to be full length. It's in two parts. One slides inside the other so the shield is not damaged as the PTO shaft length changes when you raise or lower the implement. Someone would have to have removed the other part of the shield. The uncovered part of the PTO shaft would be a safety hazard for people who got closed to it. All my PTO shaft shields have only one chain, at the tractor end. Sometimes the implement end of the shield turns, sometimes it doesn't. Its easy to stop it turning though so it's not a hazard.
Here's a pic of a PTO shaft with shields intact (it's compressed all the way so you can't see how the shield tube has two diameters):
And here's a PTO shaft without shields:
/ Erratic PTO rotation #11
I wonder if the part of the shaft the OP can see is on the mower slow down is the slip clutch itself?
Hi All,
Im starting to feel that i may be an anxious elderly newbie.
im posting photos as requested of PTO.
Ive assumed the black part i can see connected to the mower is the PTO shaft itself. But is it a separate casing which is rotating with the PTO (as it isnt chained) and rotation is reducing with friction as everything gets warm? -and perhaps crud is accumulating between this part of the pto and the slightly larger chained cover at the tractor end which is why im now noticing this.
im sorry if my descriptions are not too technical - I used to be the ornamental garden half and now I have to do and understand everything im on a steep learning curve!
P1080995 Large e-mail view.jpgP1080992 Large e-mail view.jpgP1080996 Large e-mail view.jpg
i hope the photos come through
/ Erratic PTO rotation #13
That you see is a tube that shall be secured with chain so it doesn't rotate, it's a safety guard.
Thanks Agvg -
would there be any reason that the machinery dealer who sold me the new mowing deck with pto and fitted the whole assembly didnt put a chain on the mower end?
i see now that i may have been worrying about nothing... as, after all, the engine revs dont fall off and the deck keeps cutting, hopefully because the pto is working fine and ive just been confused by a non chained guard - doh..
thanks to everyone who has helped
/ Erratic PTO rotation #15
Thanks Agvg -
Ehh....
....many on here wonder if there's a reason PTO shafts even need guards, let alone if they need to be chained. ("Just don't get close to them!" --Especially with loose, ragged clothing, shoelaces, or hoods with drawstrings. That's how people get pulled in).
In my humble opinion (IMHO), guards are good, but chaining them? ...Ehh! Whatever...
I'm not sure what the chain actually does, besides confirming that the guard can spin (not spin) freely of the enclosed shaft.
At least you were curious about and questioned why it wasn't consistently spinning.
.....rather than burning up a slip clutch. :thumbsup:
2011 Dodge Ram 5500 4x4 Terex Hi Ranger LT40 40ft. Forestry Chipper Insulated Bucket Truck (A61568)
2011 Dodge Ram...
PALADIN GSS72-72" HYD BRUSH CUTTER (A62129)
PALADIN GSS72-72"...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
Hydraulic Asphalt Scraper Skid Steer Attachment (A61567)
Hydraulic Asphalt...
2012 Can-Am Spyder Motorcycle (A61569)
2012 Can-Am Spyder...
Vision 250/50R15 77D Golf Cart Tires (A61166)
Vision 250/50R15...
