Max 22 fuel solenoid again!
/ Max 22 fuel solenoid again! #1
Max22TN
Max 22 2015
Here we go again. My tractor has another bad fuel solenoid. This is #3. It starts and runs when cranking but dies when the key is in the run position. Called the dealer and they want 270 bucks. Ouch! Ordered one on Amazon for 50. It's a different brand. Maybe this one will last?????
How do I know how far to screw it in before locking it down with the nut?
/ Max 22 fuel solenoid again! #2
man been there done that. ticked me off too my part was 236 with shipping from bill's is it. let me find the thread.
/ Max 22 fuel solenoid again! #4
Probably a little too detailed. Someone much more knowledgeable than me said to start the engine with the solenoid backed out then turn the key off and screw it in until the motor shuts off.
Thanks Doneill
/ Max 22 fuel solenoid again! #8
I'm no mechanic... start by setting the new Solenoid just like the old one.
Either measure or count the thread turns out of the old mounting, put the new one in the same way.
I got one off the Web, I could look it up if needed, did what I said above, worked.
Can't remember if it was Amazon or eBay, but it looked exactly the same, worked the same for six months, so far so good !
/ Max 22 fuel solenoid again! #9
Max22TN,
How did you make out on this ?
/ Max 22 fuel solenoid again! #12
I screwed it in as far as the old one was. It worked fine.
OK good you got it done, ... I found it very easy to replace... I was glad it worked out for both of us... !
Your go to go !
Ltr
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
832647 (A61165)
832647 (A61165)
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
