Max 22 fuel solenoid again!
   / Max 22 fuel solenoid again! #1
Max22TN
Max 22 2015
Here we go again. My tractor has another bad fuel solenoid. This is #3. It starts and runs when cranking but dies when the key is in the run position. Called the dealer and they want 270 bucks. Ouch! Ordered one on Amazon for 50. It's a different brand. Maybe this one will last?????
How do I know how far to screw it in before locking it down with the nut?
   / Max 22 fuel solenoid again! #2
man been there done that. ticked me off too my part was 236 with shipping from bill's is it. let me find the thread.
   / Max 22 fuel solenoid again! #4
Probably a little too detailed. Someone much more knowledgeable than me said to start the engine with the solenoid backed out then turn the key off and screw it in until the motor shuts off.
Thanks Doneill
   / Max 22 fuel solenoid again! #8
I'm no mechanic... start by setting the new Solenoid just like the old one.
Either measure or count the thread turns out of the old mounting, put the new one in the same way.
I got one off the Web, I could look it up if needed, did what I said above, worked.
Can't remember if it was Amazon or eBay, but it looked exactly the same, worked the same for six months, so far so good !
   / Max 22 fuel solenoid again! #9
Max22TN,
How did you make out on this ?
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
2011 Liebherr L586 (A53472)
2011 Liebherr L586...
