Loader Front loader only rises half way
/ Front loader only rises half way #1
jlyrintzis
Snohomish, WA
Kubota B2310
I have a B2620 with LA364 front loader. Out of the blue the loader only rises half way. It rises the normal speed until it stops, kind of like there is something physical limiting it from rising more. The hydraulics are still whirring when attempting to raise it more. I have inspected all the joints but can't see any physical blockage. Curling works fine both ways with full range. Any thoughts?
/ Front loader only rises half way #2
That's usually a symptom of a quick disconnect not seated right. Maybe something hit it and it popped of or is not all the way in. Check all of your quick disconnects.
/ Front loader only rises half way #3
Check your hydraulic fluid level. I'd expect it to a bit jerky if you were running low, but it you run out of fluid it will stop moving. The but end takes more fluid than the rod end of a cylinder.
/ Front loader only rises half way #4
This ^^^ especially if you have no down pressure on the boom (lift) circuit.
Thank you, the problem resolved by re-seating the quick connectors. I originally thought about that, but dismissed the thought by thinking that it would not rise at all if it was hydraulics related. Live and learn, I dodged the bullet this time. Thanks again!
/ Front loader only rises half way #6
'Live and learn' indeed. I've learnt something this morning.
Truly what TBN is all about. :thumbsup:
/ Front loader only rises half way #7
Outstanding -- how's this for the quick value of our forum !?
2012 Ford F-350 Service Truck (A61568)
2012 Ford F-350...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61567)
2025 BrushFox...
2015 Ford F-350 Service Truck (A61568)
2015 Ford F-350...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2020 BOBCAT T770 SKID STEER (A62129)
2020 BOBCAT T770...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
