water tank question
/ water tank question #1
rocco611
Madera Ca.
Kubota
For potable water , I currently have a 1000 gallon translucent plastic water tank I insulated it with foam board and covered it with tarps to keep the water cooler and protect against algae growth. I am considering building a steel 5000 gallon tank or buying a 5000 gallon plastic one. If my well goes dry in the future or I have to work on the pump again 5000 gallons seems to be the right size for water delivery they can bring 4000 at a time leaving me a 1000 gallon cushion between deliveries. with a new housing development going in and quarry as well , the future of the shallow aquifer I am in is questionable. If I build a tank from steel I am wondering if I should build it from galvanized steel and seal the weld joints with cold galvanized spray or build it from bare steel and epoxy coat it inside and spray the outside with automotive paint. I have also considered building a concrete tank. suggestions appreciated :)
/ water tank question #2
Is stainless out of the question? I have had stuff galvanized. I like the process but would have zero confidence in that spray. Can't you get a huge poly or fiberglass tank? That would be my first choice.
/ water tank question #3
You can probably get 2 - 2500 gallons cheaper than one 5000. Aren’t you guys (ca) heavy into rain water harvesting? You can always filter. Any grants available?
I perfer to work with stainless but cost is about 4x the cost of 1018 steel plate. If I could find reasonably priced stainless I would definitely go that route
/ water tank question #5
Any chance of buying a SS tank off of a scrapped truck?
/ water tank question #6
Why wouldn't you hook smaller tanks up to a modular manifold? you can then add or subtract tanks as needed?
/ water tank question #7
/ water tank question #8
You are right to be concerned about the translucent white PEX tanks.
I built my 5000-gal tank of concrete using ICFs, then contacted a big steel tank maker (King City, IIRC) to find out what to coat the insides with. I wanted something that had an NSF-PW rating for drinking water. Whether galv or plain steel, you will want full-coverage coating, in and out. It looks like black tar.
Many folks around here are required to have 10000-gal storage, so get a 10000-gal tank. Note that over 5000-gal, a permit and engineering may be required for the foundation (slab).
/ water tank question #9
Concrete would be cost effective. 1000 gl prefab sewage tanks come to mind at around $800. Or, 700 gallon (4'x8') prefab culverts can sometimes go at bargain prices if chipped and not acceptable for gov. contract work. I found some for a couple of hundred bucks each. It's a modular solution. Stand them up underground on end plugs first rimmed with sealer, devise a top seal according to needs and pipe them all together. Not sure about sealing the walls for potable water, I don't think I would fret much about that.
/ water tank question #10
I installed two 2500 gallon tanks for my 5000 gallon standby... Green poly, and opaque....Think pricing came out to about 50 cents a gallon for tanks (memory a bit foggy on that one)...
Bungs on tanks are 2 inch NPT.... Also installed a hydrant (2.5 inch NPTH) so if engine needs to connect for fire prevention ... I'm a little above you near Yosemite so fire is always in my thoughts... Most people seem to prefer plastic up here....
Red "coffee cans" protect plastic ball valves from UV radiation which will cause it to become brittle...
Dale
/ water tank question #11
Clear 1550 poly tank at Tractor Supply is $799 everyday, and you can catch them on sale cheaper than that. I have two of them in a 10x20 cinderblock building (front is wood framed/sided in case I ever needed to replace a tank) that I use for spring water storage. Put them in 1995, no problems since. I used a 1,000 septic tank I had them cast a fitting in the bottom when built prior to that. Like the above ground poly tanks a WHOLE lot better.
The TSC black ones are $1199 for 1550gal, $2000 for 3,000gal.
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
Dexter trailer axles (A61567)
Dexter trailer...
(10) New CATERPILLAR Keys (A65579)
(10) New...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
