OP
1930
- Joined
- Sep 9, 2018
- Messages
- 933
- Location
- Brandon/Ocala Florida
- Tractor
- Kubota B6100E Kubota L 2501 Kubota T1460
1. It doesn't matter as long as the battery is not too much smaller than the tray.
2. I hope you don't find that to be surprising
3. Good for that dealer. They are correct, and they are saving you money.
4. Nope. It is true that you can buy special special batteries for tractor or cars, but electrically they are so close to being the same that it doesn't matter. A special high capacity tractor battery is just not necessaryfor a small diesel tractor (under 75 hp or so) that is not being used in arctic conditions.
For something like a B6100 buying anything more than a small car battery is just a waste of money.
If you want to spend more, put your money into a good AGM type car battery that fits your battery tray.
5. Yep. Good on them as well.
6. As for deep cycle vs starting batteries....what you are hearing is true about the difference; but it doesn't make enough of a difference on a small diesel again not being used in arctic weather. Just buy the one you like best.
7. And if a battery is anywhere near the radiator (or even if it is not) then you will be much happier if you buy a sealed one. Most of the AGM type batteries on the market today are sealed batteries. They don't outgas acid fumes and never need water. Absolutely worth the money.
Be sure to clean the terminals on the battery wires. Both ends. Don't forget to clean where the (-) connector bolts to the tractor frame.
good luck,
rScotty
Underneath my hood is stained, Im guessing its a battery issue, I will need to neutralize that and will get a sealed unit, Im assuming by sealed unit you mean non serviceable in that there are no caps to remove to add water or electrolyte?
