Ballast Wheel Weights
/ Wheel Weights #1
Pabco
Member
Meadow Vista, CA
Kubota B2650 / FEL LA534 / BH77 BH
Hello. I'm looking for some input from people who have added (rear) wheel weights to their Kubota. I have a B2650 and am lookng for folks who are pleased with the product they chose for their tractor. I have several acres which have some uncomfortable slopes I need to work. Just looking for a little extra stability, aside from 3" wheel spacers. Thanks.
/ Wheel Weights #2
I always use cast iron weights rather than liquid ballast because I repair/change my own tires and have no equipment for handling liquid ballast.
That said, I do not have rear weights on my B3350 or B1750 because they are not needed for the purposes that I use these tractors.
I do not believe that Kubota offers wheel weights for the B2650/B3350 (not certain). I do not believe that there are mounting holes in the rims.
Of course, weights intended for other machines could be adapted.
SDT
/ Wheel Weights #3
These folks have quite a few weights available.
Kubota Tractor Weights
The weights #4150 fit a lot of the smaller Kubotas
/ Wheel Weights #4
I added rimguard to my Kubota L3400 and it made a world of difference. I also added steel wheel weights to my JD and they were not nearly as helpful as the 800lbs/tire of rimguard.
/ Wheel Weights #6
SDT
Very similar thoughts, I much prefer bolt on weight over liquid ballast, It performs better in my opinion and does not effect the ride as much.
It does cost more, about a buck per pound.
/ Wheel Weights #7
Agreed, Lou, and they are "easily" removed when not needed.
I've F and R weights for both my L6060 and M9960 as well as front (only) weights for my B1750 and B3350.
For those who are interested, there are aftermarket weight suppliers who sell tractor weights for considerably less than do tractor manufacturers.
There are also ways to get free shipping (to the dealer) if one is not in a great hurry.
SDT
/ Wheel Weights #8
SDT
I also prefer the bolt on weights. Our land is hilly and I use wheels set right out as wide as they will go, wide tires, and cast iron wheel weights. I've had luck setting the wheels out and not had to add spacers.
So I know it sounds too simple, but first do check that your rear wheels are set as wide as possible. Sometimes the ops manual is helpful there. Just the rears; fronts matter less. Methods of setting width vary a lot. Study yours. Tractor manufacturers seem to buy some wheels from specialty manufacturers, and wheel construction varies with price. Some wheels have centers that can be set in different positions or even reversed for width adjustment. In addition, there are wheels that have the rim adjustably bolted instead of welded to the centers.
I think that every tractor I've had has a different way to set rear width. Our old JD uses all these methods PLUS a rack and pinion to slide the wheel along the rear axle itself.
And I see others saying that there are aftermarket sources for wheel spacers and wheel weights for Kubotas that are high quality and also less expensive than OEM. You might want to search on some of the old discussion threads here.
rScotty
/ Wheel Weights #9
rScotty
North States is a manufacturer of cast iron weights as well as other things.
They sell to manufacturers (including Kubota) as well as dealers but do not sell directly to consumers.
Your dealer can (if he chooses to) order from North States. Hint: North States ships to dealers without charge if the total order is 1,000 Lbs. or more. Ask your dealer to add your order to his next order so as to get the weight up to 1,000 Lbs., to avoid shipping charges.
SDT
/ Wheel Weights #10
As you say, if they are the same weight, the bolt-on's do ride better and make things more stable.
I think that's because the weight is out farther from the centerline, no liquid means the tire can flex normally, plus there is better overall tire balance and less rotating momentum - all of which help the ride.
For a lot of new owners who are already stunned by the high price of what they just bought, the fact that the initial price of liquid ballast is half or less than the cost of adding the bolt-on style tire weights is persuasive. And it is not only just about the only affordable option but it stays a good idea until about the second time you have a flat or a need to remove a tire to do some work behind it.
My opinion is that if you plan to keep the tractor for a long time and can afford the outlay then you will be glad to have bought bolt-on wheel weights. Come to think of it, that's about the same story as anything else we buy. At least I've never heard anyone complain about the price they paid for quality tractor options ten or more years later.
So It's worth taking a look around at wheel weight manufacturers. Some wheel weights have slots and holes to make them nearly universal fit. Those type never wear or depreciate & are always worth what you paid in current dollars.
For universal wheel weights, There used to be a local iron foundary that at the end of the day's run would pour any extra molten steel into simple pre-prepared sand molds where crude castings could be sold at a slight profit or just stored & remelted. The quality of the molten metal dictated what they poured. They would pour machinable ingots for machine shops if the steel alloy was approriate, anvils if it was lesser, or if it was low quality iron they poured things like tractor wheel weights. I doubt they ever advertised anywhere. They had a pattern maker there who would make a wooden model of anything you wanted poured - like a wheel weight. From the wooden model they could quickly make as many sand molds as needed to pour into.
I wonder if the same sort of thing is still true for wheels?
At one time we could buy wheel/rim pairs that had even more adjustability built to them than a set of spacers would give. Are those type of adjustable wheel/rim sets still available? Anyone know?
rScotty
John Deere 5045E for sale
John Deere 5045E...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Giyi NWS38 Non-Connected Wood Splitter (A60463)
Giyi NWS38...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
