Kubota B7500 stops running
/ Kubota B7500 stops running #1
charlielutz
Kubota B7500
Randomly my manual transmission B7500 stops running for no apparent reason. It happens when you turn it off after using it. Does not matter if it has been running a short time or a long time. When this happens, you turn the key, the dash lights come on, but nothing, no starter, no noise. The even more weird thing is after some random time (hours, days, even a week), it start up as if there was noting wrong.
I took it into the shop when it quit running one day, they found nothing wrong with it, said they cleaned the clutch safety switch and all was good. I am wondering if that switch is bad and acts up?
Has anyone replaced that solenoid switch and if so how hard it?
Thanks for any suggestions you may have. The tractor is currently dead in the back yard and we really need to use it.
Charlie Lutz
/ Kubota B7500 stops running #2
I'm no master mechanic by any means, but since your dash lights come on, it appears your ignition switch is functioning properly. Next stop I'd look at is the solenoid between the ignition switch and starter. Try bypassing that, and see if you get the starter to engage.
Do you have a seat, safety switch? I'd check that as well. (actually I'd throw the d*** thing away myself, but that's me)
Good luck! Keep us posted.
/ Kubota B7500 stops running #3
I would look up the safety switches in the book for the tractor and troubleshoot them. It sounds like one is sticking. If you look in the worship manual, it should tell you which switches are normally open and normally closed. You can look online on how to temporarily bypass a normally open or closed switch to see which one is bad. If all are good, the starter solenoid could be sticking.
/ Kubota B7500 stops running #4
I would run a hot jumper wire from the battery to the hot side of the solenoid and see if the starter/solenoid is bad...make sure you have it out of gear also.
I had trouble one time with my RV..kelp stopping and sometimes, I would come off an exit and it would stop running .. Found out by luck it was the key switch that had a ground wire near it and would ground it out..after you would move around in the RV, I guess it would have that wire move away just enough to crank back up..Hard to think it would be something that easy to worry you after it did this for five times..also I had my tractor not starting like it was a bad low battery..found out the ground from the battery to the frame was loose..light on dash and horn work but sometimes just it would start and sometimes it would just click..tightening the bolt on the frame that had the ground from the battery and never had any more trouble..could be something like that aslo. But if it is a desiler.. that should not stop the engine from running..Some over the road tractor I had driven , had a thing in the water over flow tank and would stop the motor until you added more water back into it..could even be something like that to save the motor,,same thing for oil also..good luck on finding the fix for it.
/ Kubota B7500 stops running #5
Another thing that will keep a B7500 from starting is the PTO neutral switch. It will not start unless the PTO switch indicates that it is in neutral.
The next time it refuses to start try moving the PTO level a little bit.
Thanks guys, I'll try your suggestions tomorrow when the temperature is under 90.
Charlie
/ Kubota B7500 stops running #7
My L3700 did that...ended up being the accelerator pedal switch..it was very intermittent and aggravating. Ended up being a 20.00 part.
Wow that is a new one. HOw hard was it to replace? I am guessing you are talking about the petal not the column lever?
Thanks for the tip.
Charlie
/ Kubota B7500 stops running #9
Thanks for the tip.
Charlie
One little bolt and a plug.. took about 3 minutes. I could be wrong but i think it was called the neutral safety relay. Basically the relay that tells the tractor that the tractor accelerator pedal is not depressed.
Well, after two days of sleeping, on Thursday morning my tractor decided to wake up. I went out Thursday morning, put the key in the ignition as I had the last two days and it fired up like nothing was ever wrong!!
Frustrating, I had not had a chance to do anything to it yet but it didn't need it. Still have no idea what is going on with it. Thanks for all the suggestions.
Charlie
/ Kubota B7500 stops running #13
Your issue sounds similar to what I experience with my B2910. Usually about every 10th start, it will just click. It only happens after I have been running it hard. Usually when I've been mowing for about 2 hours and then shut her down is when it happens. I'll shut it down, take a water break, and then when I go to restart, I get "click". I'll usually try cranking about 5 times before she'll start. Pump the clutch a few times, turn the key, and after about 5 tries, it'll usually start. This never happens when the tractor is cold and has been sitting. I asked the previous owner about it, and he said he had the same issue, but it would usually start after a few tries.
I'm not sure what the cause of my issue is, but I'm certain it is heat related. It sounds like your's might be heat related as well.
/ Kubota B7500 stops running #14
I...799,
It sounds like your problem specifically, and maybe the original poster's as well, could be the result of your tractor suffering from the dreaded "click-click no start" syndrome. This apparently is common and caused by problems with the contacts in the safety circuit. They either wear, get dirty, or slightly out of adjustment while still making contact. The net result is that excessive voltage is dropped across each contact that has a problem, with the net result being there is not enough voltage reaching the starter solenoid to cause it to close. So it just clicks.
The solution is to install and interposing relay. This relay is energized by the safety circuit. Contacts of this relay feed battery voltage directly to the starter solenoid. The reason it works is because the relay coil requires much less current to operate than the starter solenoid, so more voltage reaches the relay coil then reaches the starter solenoid in the original circuit.
The following thread includes probably everything you need to know:
https://www.tractorbynet.com/forums...405-bx2200-intermittant-ignition-failure.html
I made this fix to my BX2200 and the problem I was having disappeared completely. If you do the same thing I believe yours will too.
Edit: The key is the click-click sound. If there is no click-click sound, then a switch may be failing or going totally out of adjustment, which is a different issue.
2022 CATERPILLAR 349 EXCAVATOR (A65053)
2022 CATERPILLAR...
2014 Infiniti QX60 SUV (A66738)
2014 Infiniti QX60...
2020 Bobcat E26 Mini Excavator (A66734)
2020 Bobcat E26...
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
2012 CATERPILLAR 303.5E CR EXCAVTOR (A65056)
2012 CATERPILLAR...
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
