Buying Advice Best dedicated mower for hills and rough terrain
   / Best dedicated mower for hills and rough terrain
Thanks everyone for the responses, it has given me a lot more to consider. The front mount mowers I really wasn't considering, a 4x4 front mount certainly sounds like a much better setup for my situation. I see two categories of front mounts, I do think I need a 4x4 but perhaps a traditional grasshopper style would be sufficient. I am going to keep looking and see what I can find. Thanks again.
   / Best dedicated mower for hills and rough terrain #12
My property has several hilly sections, as well as a dike around the lower side of my pond. I found that of all of the tractor/mower styles I tried (CUT w/ 3-pt mower, garden tractor, zero-turn, front mower) that the front mower works far and away better than any of the others. My tractor with a 3-pt deck works ok, but I can tackle steep hillsides sideways with the front mower, also can mow faster and result in better cut quality. I found an old New Holland 4wd CM224 for $2500 that I've been using for several years now. I'm mowing ~7 acres in about 3-1/2 hours (lots of trees, hills, buildings, etc). If I had to get another mower, I would buy a front mower.
   / Best dedicated mower for hills and rough terrain #13
in the meantime, try putting wheel weights on all 4 wheels, and front and back weights on the craftsman, load it down!. since you put AG tires on that, I don't see it slipping with the weights!.. btw, zero turns can be bought with a regular steering wheel too!. personally, I would not like using the sticks, more work..
   / Best dedicated mower for hills and rough terrain #14
Get a front mounted Kubota, Deere, Toro Groundsmaster, or Grasshopper. I have a Groundsmaster with a 6' front deck. Best hill mower I've ever owned. The long wheel base and low center of gravity makes it almost impossible to flip. I mow areas you can't hardly walk up and I mow it side hill.
What he said. I have same issue. Just settled in on a 72” cut 900 series front mount Grasshopper mower. Bad to the bone. Best setup I’ve tried to date.
   / Best dedicated mower for hills and rough terrain #15
Why would anybody would want a steering wheel on a Z-turn? :confused3:
I didn't know there was such an animal. As to more work with 'sticks'. I don't see that at all. Each stick controls a wheel. How does a steering wheel make one wheel go forward and the other backward?
   / Best dedicated mower for hills and rough terrain #16
agrred, kind of the whole point of a zero turn lol
   / Best dedicated mower for hills and rough terrain #17
I'm not a zero turn fan but with a steering wheel might consider one. :2cents:
   / Best dedicated mower for hills and rough terrain #18
   / Best dedicated mower for hills and rough terrain #20
Anyone who tries to hold a beer while mowing appreciates a steering wheel.
But it does make steep hills challenging with my old style Steiner with the dash mounted hydro control.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2006 International Bucket Truck (A55973)
2006 International...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
