Buying Advice Best dedicated mower for hills and rough terrain
   / Best dedicated mower for hills and rough terrain
Thanks everyone for the responses, it has given me a lot more to consider. The front mount mowers I really wasn't considering, a 4x4 front mount certainly sounds like a much better setup for my situation. I see two categories of front mounts, I do think I need a 4x4 but perhaps a traditional grasshopper style would be sufficient. I am going to keep looking and see what I can find. Thanks again.
   / Best dedicated mower for hills and rough terrain #12
My property has several hilly sections, as well as a dike around the lower side of my pond. I found that of all of the tractor/mower styles I tried (CUT w/ 3-pt mower, garden tractor, zero-turn, front mower) that the front mower works far and away better than any of the others. My tractor with a 3-pt deck works ok, but I can tackle steep hillsides sideways with the front mower, also can mow faster and result in better cut quality. I found an old New Holland 4wd CM224 for $2500 that I've been using for several years now. I'm mowing ~7 acres in about 3-1/2 hours (lots of trees, hills, buildings, etc). If I had to get another mower, I would buy a front mower.
   / Best dedicated mower for hills and rough terrain #13
in the meantime, try putting wheel weights on all 4 wheels, and front and back weights on the craftsman, load it down!. since you put AG tires on that, I don't see it slipping with the weights!.. btw, zero turns can be bought with a regular steering wheel too!. personally, I would not like using the sticks, more work..
   / Best dedicated mower for hills and rough terrain #14
Get a front mounted Kubota, Deere, Toro Groundsmaster, or Grasshopper. I have a Groundsmaster with a 6' front deck. Best hill mower I've ever owned. The long wheel base and low center of gravity makes it almost impossible to flip. I mow areas you can't hardly walk up and I mow it side hill.
What he said. I have same issue. Just settled in on a 72” cut 900 series front mount Grasshopper mower. Bad to the bone. Best setup I’ve tried to date.
   / Best dedicated mower for hills and rough terrain #15
Why would anybody would want a steering wheel on a Z-turn? :confused3:
I didn't know there was such an animal. As to more work with 'sticks'. I don't see that at all. Each stick controls a wheel. How does a steering wheel make one wheel go forward and the other backward?
   / Best dedicated mower for hills and rough terrain #16
agrred, kind of the whole point of a zero turn lol
   / Best dedicated mower for hills and rough terrain #17
I'm not a zero turn fan but with a steering wheel might consider one. :2cents:
   / Best dedicated mower for hills and rough terrain #18
   / Best dedicated mower for hills and rough terrain #20
Anyone who tries to hold a beer while mowing appreciates a steering wheel.
But it does make steep hills challenging with my old style Steiner with the dash mounted hydro control.
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2020 Chevy Silverado (A56435)
2020 Chevy...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
John Deere 5055E (A53317)
John Deere 5055E...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
