Man killed trying to separate PTO shaft with tractor
   / Man killed trying to separate PTO shaft with tractor #21
IMO, the tractor wheelied over. Front end came over and flipped, like the article stated.
   / Man killed trying to separate PTO shaft with tractor #22
I don't claim to be a farmer although around tractors all my life. I had my share of close calls but was lucky.
My JD cuts off if PTO is on and I get out of seat. There's no reason imho to be near a running PTO. Neighbor's Dad got his shirt caught in one. He survived luckily since shirt ripped off of him.
I twisted my best friend around a auger pto shaft once digging fence post holes, I heard his death scream and immediately shut the tractor off. He had a flannel shirt on and it got hung on the pto shaft. I had to cut his shirt off him to get him loose. One more second and it would have been much worse. I learned a valuable lesson that day.
   / Man killed trying to separate PTO shaft with tractor #24
and if he had chained it to the drawbar under the tractors chassis, there is no way for the tractor to flip over backwards.
Not unless he ran out of enough torque to tip the tractor up. You dropped the center, but unless you unhook your tractor, it can still come up.
   / Man killed trying to separate PTO shaft with tractor #26
Most of the time we are lucky when we do our work in a possibly risky fashion. It is sad that this man was not lucky on his final day. :(
   / Man killed trying to separate PTO shaft with tractor #27
Holy cow!
:eek:
That could go awful in a second.
So sorry for the family. With more details, the story could be a lesson for others. Like others have said, even them mentioning a PTO shaft is a lot more detail than most stories.
How did it happen?: Are there really any tractors that have a pto connection above the axle? It seems very, very unlikely the pto shaft was connected to the tractor's pto spline. You'd break castings and bearing if you used this connection as a pulling point, and it's not high enough to flip the tractor backwards even if you did; and no way would turning PTO on flip a tractor sideways like a rotisserie.
It's seems very likely he chained the PTO shaft to the tractor (like the story says) at a point above the rear axles that causes the tractor to rotate backwards.
The lesson is: Don't do that!
Many people don't know not to do that. Example, India has a billion people, and if you've ever watched tractor videos from there, not 1 in a billion knows not to do that!
   / Man killed trying to separate PTO shaft with tractor #28
I'd never been on a tractor of any size before I got mine six months ago, but I knew from mowers and other things that you would want to connect as low to the center of gravity as possible if you were going to try to pull and keep the front end down. But for all we know, he may have been connected low, but was on a slope, or in soft ground and some motion caused him to go sideways.
   / Man killed trying to separate PTO shaft with tractor #29
Always sad to hear of an accidental death.
I had to pull a stuck shaft apart once but I didn't have it connected to the pto shaft of the tractor. I think I ran a bolt and chain through both ujoints. Been a long time ago.
   / Man killed trying to separate PTO shaft with tractor #30
Being an older Oliver tractor I suspect it was connected to the drawbar, and yes the older tractors had light front ends and would pull the front end off the ground and tip over backwards. Many a farmer was killed when plowing and the moldboard would catch a stump or something, and over they would go.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
