Doing It In Mud
/ Doing It In Mud #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Hi TBN'ers,
I have no pics, but thought posting about working in mud might bring up some interesting responses.
Yesterday my neighbor called me to bury an Alpaca that she had to put down. There was/is standing water in our fields from days after days of rain. I decided to give it a try with my B2620, since the rather large animal will bloat and be quite a mess in a few day.
I put a Middle Buster on the 3-pt to loosen the turf for scooping with the FEL. The short version is that it was quite a mess, but I got'er done. Hosing the mud off the tractor took just about as long as the main event.
Y'All having to deal with this lousy wet weather? And don't ask me about my garden.:mad:
Cheers,
Mike
/ Doing It In Mud #2
I hate when "mud" season kicks in. Had the tractor stuck several times over the hill. The R4 are great 90% of the time but on a hill in the mud they are horrible.
Last time I got the tractor stuck I asked my wife to come outside and press the hydro pedal so the wheels would turn in reverse while I gave it a pull with the excavator. Simple easy plan that almost went wrong. She hopped on the 50hp 4x4 tractor, throttled it up. I dropped the excavator blade, extended the excavator arm and hooked the chain on the bucket and hooped back up on the excavator. I did NOT put the seatbelt on since I was basically just giving a slight pull on the chain to get the tractor up the greasy hillside (not buried at all - the tractor tires just got loaded up and were on top of a thin layer of mud). Like an idiot I was learning forward and motioned for my wife to reverse the tractor so the wheels would be helping move the tractor and I was just about to take up the slack in the chain (Think HD chain - ½" thick links). Well she got the forward/reverse confused and hit the hydrostatic drive full bore forward DOWN the hill. The slack came right out of the chain and yanked hard on the extended excavator arm. This propelled me forward off my seat and I lucked out by catching both roll cage bars (one on each side) with my extended arms as I flew forward. I sort of hung out over the front blade with my feet hooked on the bottom front edge of the open cab and both arms slightly behind me and spread apart holding the cage. Thankfully she realized what she did and let off the go pedal before I fully ejected. After a few seconds I returned to my seat, cursed under my breath and yelled down to her, "other pedal dear....."
/ Doing It In Mud #3
Wet weather?! I don't have to worry about visitors, I have a mud moat. Nobody can get in to visit me unless they have 4 wheel drive and a winch. As for a garden, instead of corn and beans, I'm trying to decide what to raise, either catfish or tilapia?
Still working on repairs from the hail storm a couple of weeks ago, before I can get back to the projects I've postponed until hail damage is repaired and things dry out a little.
As much damage as we've had, I still feel fortunate because many people around here have it much worse than us.
/ Doing It In Mud #4
Mud? What mud? :laughing:
A week ago this was my back lawn.
Now taking applications fer mud wrastlin' girls. LOL
/ Doing It In Mud #5
So, how deep is that mud? Is that a building at the back of the picture or a retaining wall. It looks like there is a crack in the bricks.
/ Doing It In Mud #6
How deep? Depends which part. I had just dug 4 tranches for a ground system for some ham radio antennas, so anywhere between 6" and 2'. lol
That's the back of my house. Damage was done before we moved in. Matthews wall anchors had already been installed in the foundation to remedy.
/ Doing It In Mud #7
No pictures but I tried crossing seasonal creek and made it across, did some work and coming back sank my MF GC 1715 right up to chassis, all it did was spin all four wheels and sink deeper.... Had to get jeep and winch it out... It was suck enough the it slid Jeep across the ground and I had to lock Jeep down in 4WD and block the wheels...
Dale
/ Doing It In Mud #8
Mud equals double work bring sour attitude.
/ Doing It In Mud #9
You have far more self control than 90% of us! Thankful that you weren't killed, although I'm sure you did suffer some minor injuries.
/ Doing It In Mud #10
Last night I was towing a little cart around behind the ATV gathering up the wood I'd sawed up here and there last fall.
Thought it would be a good idea to venture down to the "low land" where spring floods washed away my culvert to check out when I'll be able to replace it.
Approaching the bottom, I'd forgotten that I'd turned off 4wd when I was on the paved driveway. I go about 6 feet, start coming to a stop, gun it to keep moving and floating on top, but end up and sinking right up to the belly skids. Thaaats when I realize 4WD was off. That was my first mistake.
My second mistake was not unhooking the trailer. The paddle-tread rear tires are good, I could slowly move through the muck if I gunned it. However the cart acted like a nice backboard for the 5 gallons of mud-per-second that rebounded off it back onto the 4-wheeler and the driver, but once moving it was a :"Can't stop now!" situation.
Needless to say, I got covered, had to strip on the porch. and will be spending some time cleaning the 50 pounds of mud off it in the coming days.
/ Doing It In Mud #11
After three hours of self recovery with building a log grid under the tractor.... and another hour pressure washing..... I'm avoiding the mud for a while.
/ Doing It In Mud
What got me is how heavy and sticky the muddy turf/ground was. I could hardly move it when trying to finish covering the animal with a shovel. Sometimes the muck would stick in the FEL and barely shake out. Maybe a backhoe could have done a better job.
/ Doing It In Mud #13
New home construction. At the entrance to my dooryard I had 40 feet of deep gravely slop. Was using tractor to transport fireplace mortar and block from driveway to house and had gotten it stuck twice before but got it out after unloading bucket and using it to push myself out. The third time I was mired good. Had to use excavator to pull it out. First pic was after I had gotten it unstuck the second time. Second pic was the time the excavator pulled me out. Gotta remember that even with studded chains its not a skidder.
/ Doing It In Mud #14
Thanks! A little later It was pretty funny, but at the time I really didn't see the humor in it. Have to admit I was a bit sore the next day, this getting older is no fun!
/ Doing It In Mud #15
Hi TBN'ers,
Had to do a little bigger hole .... for a cow. Surface was dry, but the ground is overly wet from months of too much rain. Wet clay tends to pack like PlayDoh in a BH bucket, and it doesn't like to fall out, even with the help of a shovel.
/ Doing It In Mud #16
My ground is in the bottoms and it is currently under about 8’ of water. It will be a mess when the river goes down.
/ Doing It In Mud #17
Mainahs...you need to round up and lay down some of those FIELD PALLETS to build yourself a temporary haul road.
/ Doing It In Mud #18
The rain is delaying everything. I got my tractor stuck with just turning it around near a low spot. I had to use to logs under the bucket to raise it up and then a come-along to winch it out. Took 3+ hours
Thinking of fabricating a receiver hitch that I can hook up to my 3pt hitch receiver.
/ Doing It In Mud #19
Making your own would be a fun project but your Deere dealer will sell you one that is green and i-Match compatible for about $150
Google Express
/ Doing It In Mud #20
Had it mucked out and 12 loads of bank run brought in. Too much for my tractor. All better now. :)
4004SFL (A59228)
4004SFL (A59228)
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
