Newbie question #1
/ Newbie question #1 #1
Tpondel
Gold Member
NW OHio
Deere 3033r
I recently bought a 3033r.
Having issues getting the transmission into the right gear. A is easy. So is C.
What's the secret to hitting B?
Thanks
/ Newbie question #1 #2
If this is a hydrostatic transmission sometimes you need to press on the FWD or REV pedal slightly to take the pressure off the gears. This is because they are straight cut gears and any tension on them can make it hard to change ranges.
/ Newbie question #1 #3
How about some info on your tractor and what your doing.
Power reverser or hst?
What gear do you have the unit in ? When trying to shift the ABC range
Are you moving or parked?
Idle or low or high rpms?
Are you operating any attachments at the same time as shifting?
PTO on during any of this ?
Any other information you can think of to help out
Parked, gear ..
Just trying to go from C to B
Idle
No PTO running
No attachments running when shifting.
Literally just sitting there parked trying to get it into B
/ Newbie question #1 #5
As jgayman says and the operator's manual also says..
The transmission range shift lever (A) provides three speed ranges and is used in conjunction with the forward travel pedal (C) and reverse travel pedal (D).
With using travel pedal in conjunction with the range shift lever, the three ranges and neutral can be found rather easily. Not when "parked" .
It will be a "learned" feeling with operating time on the tractor. ;)
Don't force the range shift lever or you may be asking the question others have already asked.. "how to repair the broken shift lever ?".
Ahhhhh. Thank you! I'll give it a try.
/ Newbie question #1 #7
Plus 1 on that. I almost always fiddiddle w the pedals to “disengage” the drive system before I can shift the range.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
SAND BLASTER AND GEAR (A60736)
SAND BLASTER AND...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A60736)
1994 SHOP MADE...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
