3-Point Hitch How To Avoid Bending Lift Arm Adjuster ... (Again)?
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Noticed this as I was hooking up the BH this morning. I'm pretty sure it happened while using the Landscape Rake since I had to adjust them almost all the way out to get the spread for the pins. But I'm not sure why it happened or how to avoid doing it next time. There are no stabilizer arms and I don't see a way to add any. Thinking maybe a threaded rod coupler all the way on then backed out to the turn buckle to add strength?
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #2
I can not see or imagine the entire image,, so I have to "guess" what I am looking at,,,
A LOT of "redesign" occurs,, and is shown on the forum,,
These components like your rod, were only intended for use in tension,,
An attachment is "re-purposed", which results in compressive force on the rod,, Oops,, the rod bends,,
Can we see more??
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #3
They usually bend like that when you back into something.
Can we see more??
Nothing redesigned.
BH is on now so lift arms are raised and I can't get a decent 'now' picture. These were taken for another reason but show them fairly well (orange arrows) Red arrow points to what was bent and shown above.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #5
The only way it could probably bend like that is being put into compression, which of course they are not designed to handle. The way to avoid that is proper adjustment so that when the implement sways side to side, one link goes into tension and the other goes slack.
Normally the link attachments are designed so this automatically happens (one side will slack rather than compress) but there needs to be the right amount of slop. If the load side never goes into tension before the slack side runs out of space to slacken, then it could get pinched and bend.
I always give implements a quick eyeball to make sure the links behave properly. It can vary with height on some tractors, so check it high and low to be sure.
Well, this was the first time I used the rake, so I'm not really sure if I had it adjusted right or not. But I also had the carry all on and moved a few pallets, so maybe it was backing into/under those.
But that's why I was asking about a rod coupler to increase the overall diameter of the shanks.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #7
I wouldn't take that approach since it doesn't address the fundamental problem and may end up causing something else to break worse. Just adjust the stabilizers carefully so that they cannot get pinched and go into compression. You always want one of them (the one opposite of the sway) to go into tension and take all the load. The other will become slack and loose in that situation and not do anything.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #8
don't back up with the implement on the ground.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #9
Mine are busted, did you figure out a better solution? Wonder if anyone makes a kit with the bar/pins for easier adjustment? The factory arrangement does seem cheezy, not sure if I will replace with factory parts again or not.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #10
You have to be careful with the bars too. I have tubes with plates that slide into the tubes on my B series and I bent one of mine slinging a brushcutter into a stump on a turn.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #11
JMHO - s219 has the answer. My big 'ol heavy rear blade is on the 3-point. I push the blade HARD to either side. The stabilizer on one side is in tension - opposite side is slack.
Proper adjustment is the answer - not going bigger. Going bigger is like putting a Grade 8 shear bolt on your PTO drive line when it should only be Grade 5. The bolt will not shear now but something else could likely break.
Another thing I notice. Where the stabilizer rods attach to your tractor is narrow - where they attach to your backhoe arms is wide. That is the direct opposite of how it is on my M6040. My stabilizer bar attachment points on my tractor are wide. Where they connect to the 3-point lift arms is narrower.
Put more plainly - your stabilizer rods are INSIDE your 3-point arms. The stabilizer rods on my M6040 are OUTSIDE my 3-point arms.
Will this make a difference - you betcha. You and I are on opposite ends of a rope. You space your feet only a foot apart. I space my feet at three feet apart. Who has the better "foundation" and can pull the hardest before they topple.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #12
Related question: should the stabilizers have that slack or should they both be tightened so that the implement is fixed in place or should there be some play in the side-to-side?
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #13
My heaviest 3-point implement is my Rhino 950 - 8' wide - 1100#. I have it set up so that at FULL rise there is about 1 1/2" of slop to the left of dead center - same to the right. Full rise is when the stabilizer shackles would be at their greatest extension.
Again - if you adjust the stabilizers when at a position less than full extension - bad things can happen when you DO lift to full extension. My stabilizers are NOT like bungee cords.
I never tighten the shackles to dead-nuts full tight. No matter which implement I have on the 3-point.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #14
makes sense. I always have slack in mine, but I always wondered if the abrupt swing to the side when turning would eventually harm. I did break one of the stabilizier arm links once. It was a solid, welded link between the tractor frame and the arm.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #15
I'm always pretty careful with that big 'ol rear blade swinging out back there on the 3-point. That's an awful lot of force that can be generated if I should decide to go "hog wild" while traveling around the property. When I go over bumps - definitely know/feel that heavy blade out back.
With the blade on the ground - all the swingin' & swayin' are totally gone. And if I get too aggressive - a whole lot of grunt and the turbo will spool up.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #16
Sometimes all the new technology forgets what used to work a long time ago. When you put it back together, put a couple of large links of chain at one end of the threaded rod so that the adjustment can only pull, not push. They used to use chains instead of solid rods for this very reason.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #17
Smaller length turnbuckle and add a couple links of chain that will allow for some slack but you will need to be careful swinging around you don't get it slamming back and forth.
/ How To Avoid Bending Lift Arm Adjuster ... (Again)? #18
You just put a few links of chain on so you can tighten both sides up, put tension on the arms, and stop the swinging. But if you back into something, the tension pulling on one side stops it from going further instead of an arm trying to hold it in place by pushing on the other side.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2007 JLG 600S Manlift (A61166)
2007 JLG 600S...
