What do YOU use to cut metal roof panels?
/ What do YOU use to cut metal roof panels? #21
Those snips in the video will work OK but there are heavier ones available. They look like a heavy duty aviation snip but with the side snip design. I got a chance to use these before and they are the way to go.
/ What do YOU use to cut metal roof panels? #22
I formerly used a cut-off wheel and snips. No more. A metal cutting blade in a circular saw does better and lasts longer. The abrasive blade wore down and got slower and won't cut the ribs when the diameter got too small.
The metal cutting blade with carbide tips keeps the heat to a minimum too. Not just any carbide tipped blade... Has to be a metal cutting blade. The carbide is different than a wood blade.
Use safety googles in any cutting. Metal chips or grit in the eye hurts. Hearing protection is good too.
It's all fun until someone gets hurt.:thumbdown:
https://www.homedepot.com/p/Diablo-7-1-4-in-x-48-Teeth-Steel-Demon-Ferrous-Metal-Cutting-Saw-Blade-D0748F/100098833
/ What do YOU use to cut metal roof panels? #23
I built a LARGE metal shed, and made a LOT of cuts with a Milwaukee nibbler,,
I may just buy this saw the next time I need to cut something my Milwaukee band saw will not cut,,,
/ What do YOU use to cut metal roof panels? #24
Cheap HF air nibbler does work but can struggle getting over ribs. I bought one of those power shears you attach to your battery drill and it worked better but sometimes could have problems going over ribs. another thread on the subject
/ What do YOU use to cut metal roof panels? #25
Metal cutting blade for circular saw. Nibbler for trim and small cuts. I don't like abrasives. It seems to heat the metal too much.
/ What do YOU use to cut metal roof panels? #26
I too went the nibbler route. Makita JN 1601. Made a clamp on guide for long straight cuts.
/ What do YOU use to cut metal roof panels? #29
A Plasma Cutter is probably what you are looking for!..
Plasma cutters have their place, I don't think cutting roof tin is it though. It burns the edge farther back than a saw or snips and will rust sooner, not to mention if it's painted tin you have to have a ground which means more bare metal.
/ What do YOU use to cut metal roof panels? #30
/ What do YOU use to cut metal roof panels? #31
I never heard of the backwards blade, just carbide. I guess a blade cuts the material and an abrasive wheel burns through it. I don't think you want that heat to mess up the enamel. Plasma is just out of the question. Hard to go up and down the ribs anyway.
My Roofer had this really long, expensive looking, hand held, electric snips type of tool.
/ What do YOU use to cut metal roof panels? #32
Well I did more than a few metal roofs.
One time I came across a blade that had no teeth, no carbide, just a whole bunch of slits. Looked like an unfinished blade.
Well great surprise! That blade did the best job of anything I had ever tried.
Guess you might call it a 'friction blade'. OK I made little curls of metal and slightly discolored the last 1/8 " of roofing but by golly did a great job.
Problem is I rarely see it in Box stores so U need to search for them.
To look at them. they have slits every inch or so with no teeth, much like they were unfinished production carbide blades.
If U find some, try and U will be amazed.
OK, noisy but cutting metal roofing what do U expect.
/ What do YOU use to cut metal roof panels? #33
/ What do YOU use to cut metal roof panels? #34
I use an electric nibbler -- my dad gave me his old one, an Ingersol-Rand industrial nibbler from the 1980s. It's going to need a sharpening soon, and the cord is in rough shape, but it cuts great and is fast.
I was told using any sort of rotating saw blade causes two problems. First, the raw edges will be more prone to rust. The high speed and heat will temper the edges and make them very prone to rust. Snips or nibbler will polish the edge when they cut, and actually ward off rust. Second, the combination of heat from the cutting and throwing of hot chips or abrasives can damage the galvanizing and paint on panels.
Last time I custom ordered metal roofing, the company said the warranty would be voided if any cuts were made with a saw. I found that odd since I ordered all the panels made to my specified length and had no cuts planned for that project, but I guess they wanted to make sure I knew the policy.
/ What do YOU use to cut metal roof panels? #35
I cringe when I see guys cutting stuff and don't give a crap about where the metal goes. Typical construction attitude. Not my problem, here and now.
/ What do YOU use to cut metal roof panels? #36
Starting a roof project, 29G 5 Rib panels and trim ordered. In the past, I've used an abrasive cutoff blade in a regular circular saw. Tin snips/shears are OK for small pieces and trim, but they don't work well for me for long cuts. Considering an air or electric nibbler or shear. I seem to recall some posts here about people using regular circular saw blades, but I'm not sure how well they would work.
So, what have YOU used?
I used harbor freight electric shear to cut all my barn metal.
/ What do YOU use to cut metal roof panels? #37
I
Well, it does burn the cut edges a bit, but I'm not sure why it would be an issue for areas of the panel not cut. Then again, shears and nibblers leave an open metal edge too.
When i was considering doing a metal roof, i went directly to the factory for Metal Sales (a major manufacturer/supplier of metal panels in this area). One of their tech guys was kind enough to walk me through the general installation procedures and one of his key points was never to use any sort of saw to cut panels (shear/nibbler only). The dust or chips that come off hot end up embedding in the paint and damaging it, causing rust. And that was not covered by warranty. So I would agree with what the previous poster said about teh paint warranty. Now if it's a barn or shed and you don't care, then go crazy...
/ What do YOU use to cut metal roof panels? #38
I've used a circular saw with a carbide tipped blade. It does throw some metal shavings, though, so wear eye protection!!! It's significantly faster than an angle grinder with a cutting blade (which also throws small pieces of metal, so same caution above!) and tin snips, as well as being easier to use.
/ What do YOU use to cut metal roof panels? #39
I use a regular cordless circular saw, cheap blades, and do not turn the blade backwards. Fastest method and good enough.
I have an electric HF nibbler. It works okay but the ribs make it slower. And you have to fight with the curled scrap in front of the nibbler. I suppose if I had to use it everyday I'd get better.
I also have tin snips but they are just a case of frustration. I have a manual nibbler and it works pretty good for touch up.
Would strongly recommend not using carbide tipped blades. Tried that once (blade backward) and those tips are some serious shrapnel when they come loose. And they will.
Gloves and eye/face protection advised. Long sleeve shirt wouldn't hurt either.
Sent from my SM-T377V using TractorByNet mobile app
/ What do YOU use to cut metal roof panels? #40
I once had that kind of a blade. I could never get it to cut straight for more than about a foot. It would always curve to the right, no matter what. I suspect it got hotter on one side and warped into a shallow dish-shape.
Bruce
flatbed trailer 24ft (A56857)
flatbed trailer...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
