Want a MIG welder, but what kind?
   / Want a MIG welder, but what kind? #21
I have worked on an old Hobart MIG Welder Several Times for a friend. It has welded thousands of farm gates. It is an amazing machine, does everything that a 250 class Miller or Lincoln will do and not a transistor in the thing! Only problem ever was main contactor issues. You should be able to find one cheap, because it's out of date and not sexy, but if I ever come across one, I would grab it.
Another welder I fixed for the same friend. Look at all the electronics that are absolutely unnecessary!
   / Want a MIG welder, but what kind? #22
I have the Hobart 210MVP.
It is dual voltage.
Has worked perfectly out of the box.
I have used it on flux core on 110 and 220, mig on mix, and mig aluminum with straight argon.
The welder just flat works. I wished I was as good as it is!
The only thing is that it is a transformer based machine and heavy at 80 lbs to lug around compared to one of Mark’s Everlast inverter type. You’ll want a cart or dolly if you move it much.
   / Want a MIG welder, but what kind? #23
It is dual voltage.
I think the values of both the Hobart Handler 190, and the 210MVP are impossible to beat.
   / Want a MIG welder, but what kind? #24
Hi. AS you say You already have a stick welder. Then You don't need flux core.
I Discovered I could weld lighter material using 3/32 rods Than I could with Fluxcore wire.
I Have a Lincoln 180 I Bought for welding the lighter stuff around the farm, Most of my welding
is done with an engine drive. But one of my best buys was a small inverter stick welder With the
digital read out it can be fine tuned almost amp by amp to weld almost anything I ever need
I Run my mig on c25 gas But hardly ever need it now. esp with the price of gas here in Manitoba.
   / Want a MIG welder, but what kind? #25
In the lower price range you might take a look at Century or LOTOS . LOTOS is one of the better brands of imported welders. Hobart and Forney are pretty good too from what I have heard. I have a Century mig welder ( now owned by Lincoln ) I bought at Costco in 1996 it is 120v . it does a great job on steel up to 3/16 using .023 wire and blended gas for better penetration. this is my go to welder for autobody work I use it a lot it has never given me any problems .
OP here. How important are the controls that are set in incremental stages vs. variable controls? I looked at a Hobart 190 and was concerned that the weld was somewhere in between the settings given. Or is in a non-important question?
   / Want a MIG welder, but what kind? #27
I have used both types of controls , I prefer the variable controls for welding thin material at lower current. incremental is fine on when welding thicker material at higher current. example , my millermatic 210 is too hot for sheetmetal even at the lowest setting #1 but welding 1/8" to 1/2" material the incremental settings are fine. A lot depends on the total current available from the machine as to how much difference there is between incremental settings.
   / Want a MIG welder, but what kind? #28
I'm sure glad my Millermatic 211 is variable.
   / Want a MIG welder, but what kind? #29
"I'm sure glad my Millermatic 211 is variable"
Me too Mark; both my mm211digital and mm252 have welded everything from 14 ga. fence wire welded to emt conduit, up to 3/4" flat bar and never change wire size from .035".
Hint - on the fence wire to EMT, I set for 17.5 volts/180 IPM (low end for 16 ga.), strike off on the EMT (about 1/2 second) then flick it over to the wire for about 1/4 second and DONE...
The 3/4" flat bar takes a bit more juice and time :D ...Steve
Yeah, I know; pics or it didn't happen :rolleyes:
   / Want a MIG welder, but what kind? #30
Right now, the Everlast Power i-MIG is 20% off. It will MIG and Stick weld. I've personally used one down to 22 gauge with .030" wire, and up to 3/8" and 1/2" material with .035".
2023 PETERBILT 567 VOLUMETRIC CONCRETE TRUCK (A55745)
2023 PETERBILT 567...
2018 JLG T350 PORTABLE ELECTRIC MANLIFT (A52706)
2018 JLG T350...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
Hyster 80 Forklift (A54865)
Hyster 80 Forklift...
