Sod Cutter?
/ Sod Cutter? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I have an area that I plan to open up to plant some things next year. For some odd reason, it has better grass than my lawn areas around the house. This year, as a test, I moved a few pieces of it and they seem to have taken well. I used the Subsoiler to slice rows about 18" or so wide and a few feet long, then used the FEL bucket to slice and lift those few pieces. Since we all know that's not what an FEL is for, I don't want to do that in any quantity. Plus, it was hard to get it level and flush to the ground to make a clean cut, so I got a lot more dirt than I'd hoped.
Do they make any kind of tractor mounted sod cutter? Or are they fully separate machines?
Unless it was very low cost, this is something I might rent rather than buy since it would be for such limited use.
Or maybe some ideas for a home brew tool?
/ Sod Cutter? #2
we rented one at a local sunbelt for a project similar to what you describe. i dont think i have seen a tractor mounted device, besides what a sod farm may use.
/ Sod Cutter? #4
/ Sod Cutter? #5
I think the trick to a sod cutter is blade motion,, not just "push"
you need something like the motion of a sickle mower,, or vibration back and forth to cut the sod.
If you just push a cutter,, you will get a balled up mess,,,:eek:
/ Sod Cutter?
Go back,, and read the AD again,,
"This sod blade is pre boxed in quantities of 8."
Hmmmmmmmm,, I would make that cutter before I spent $300+....
I read that and I was going to clarify it with the vendor if I thought I could make one work. Or wondered about how to make one, even before I went looking for them
They sell a manual 'kick/push' version with a couple of wooden handles, sort of like a wheelbarrow. My knees would never allow me to use that kind though.
I also saw one rigged up for a Ventrac that was push/pull only. And another that looked like somebody adapted one to a lawn roller unit.
/ Sod Cutter? #7
/ Sod Cutter? #9
When we developed our garden area ( 100 x 150 ) it was virgin meadow. Manually cutting, lifting & relocating that much sod was just too much.
I purchased and used the biggest Troy Bilt - 8hp - Horse to grind up the sod and combine it with the underlying soil.
The tall grass proved to be a real PITA. I was new to this adventure. Had I known - I would have waited until late summer/fall and first mowed, then burned the area.
However - I followed the galloping beast around the garden plot and after about three complete tillings - it was good to go.
I suggest - a 3-point tiller and simply incorporate the sod into the ground below it. Do whatever works best to kill the grass prior to tilling.
/ Sod Cutter?
They rent for $95 a day or $300 a week around here.
Why would I rent something for $95/day or more if I can buy a blade for $50 or less to attach to a Carry All temporarily and have for future use?
That's what I'll be doing for most of the area, but I'd like to be able to lift and transplant a few pieces to patch other areas near the house
/ Sod Cutter? #11
the sod cutter is a lot more than just 1 part, you also need the rest of the machine!.. THAT is why it's much cheaper to rent one, unless you would get some satisfaction out of buying or making the rest of the needed parts to make a sod cutter that will work!..
/ Sod Cutter?
The sod cutter is the blade linked above or a few similar ones I've found. The 'rest of the machine' is the power to push or pull the blade, which can even be your leg as shown in the manual version above. I'd like to find a way to use my tractor instead of my knees.
/ Sod Cutter? #13
I've used this type of sod cutter on several occasions. They work very well, but are very labor intensive. The blade does not vibrate or flex. It is fixed, facing straight forward. You kick it to advance it. You'll also notice it has a roller in front and a bar across it. That helps to maintain a consistent depth.
So if you do build one for you tractor, keep in mind you should probably have a roller or such to help you maintain your depth.
If it were me, and it was any area more than about 10'x20', I'd rent the power version locally and be done with it.
Also, sod around here is cheap. So investigate the cost of sod purchase VS cutting your own. It may be near the price of a power cutter rental and half the work!
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
16ft Southland enclosed trailer (A64047)
16ft Southland...
2018 ATLAS COPCO LED LIGHT PLANT (A63569)
2018 ATLAS COPCO...
Friesen 240 Seed Tender (A63116)
Friesen 240 Seed...
