ck3510se small bolts on loader keep backing out
/ ck3510se small bolts on loader keep backing out #1
NYCheese
Near Binghamton NY
Kioti CK3510se hst TLB
Not my picture, just grabbed it off google to show the problem bolts. They're the short bolts that hold the little teardrop shaped plates on. I noticed it because one of them came completely out, and the teardrop plate had spun 180 degrees, and grease was everywhere. I checked them all, and the 2 circled were loose on both sides, none of the others were. Seems strange that the same ones backed out on both sides....am I using the loader improperly in some way to cause it?
/ ck3510se small bolts on loader keep backing out #2
It is a common problem. take out bolts. Clean bolt and hole with some good solvent. You are looking to get the hole threads and bolts clean and dry. They will be very greasy. Put on red locktite on bolt. Put it back in with the appropriate torque. Re-grease the zerk/joint. You are done.
Thanks, I was planning on locktite, just wanted to check and make sure I wasn't doing something to cause them to keep backing out.
/ ck3510se small bolts on loader keep backing out #4
Nope, I have had several back out until I locktited them in. They were grease covered in the threads.
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
2021 Chevrolet Express 2500 Cargo Van (A61568)
2021 Chevrolet...
7102 (A61567)
7102 (A61567)
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
2016 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2016 EH Wachs Trav...
