Your Advices for New Rotary Cutter Design
   / Your Advices for New Rotary Cutter Design #1
Exchanger
Member
Same
Hi everyone,
I am a design specialist. Right now i am working on rotary cutter design for SD, MD and HD models for a huge company. Models will be available in the market next year. Clearly i can not share the company. The company and i want to satisfy our customers. Long story short, i would like to know what are your problems and needs ? Do you have any expectations which you don't find in the market. I know it's a simple machine but the market is very contentious. I want to do the best and affordable. Thank you in advance for your participation.
Models will be single spindle. (48", 60", 72" and 84")
Best regards.
   / Your Advices for New Rotary Cutter Design #2
Most people want heavy duty and cheap. Obviously you can’t have both.
You have people who want the best and can afford it then you have people like me who want the best and have to buy used and fix whatever is wrong with it.
Thank you for your reply.
Actually i am planning that our medium duty cutters will be heavy duty cutter in the market, And our standard duty will be medium duty in the market. We have the opportunity to do cheap and HD. I believe, price/performance ratio will be good. If you have any recommendation, please do not hesitate to say.
   / Your Advices for New Rotary Cutter Design #4
I cut at a very low deck position and the my skid shoes on both sides tend to scrape in turns. I would like some sort of anti-scrape wheels to retrofit on both sides of my old Agri-cutter AC-205. Something like an omni-wheel on both sides.
   / Your Advices for New Rotary Cutter Design #5
Will it all be made in America?
   / Your Advices for New Rotary Cutter Design #6
I second this - I have often wished for guide wheels on the front of my bush hog.
Sir, it's a good point. Thank you for sharing. I will consider this.
I believe so, i sad this because of the production amount. But i have to asked: Does it matter for you ? Cause it is a good feedback for marketting.
Guide wheel for what exactly ? I mean why do you need quide wheel ?
   / Your Advices for New Rotary Cutter Design #10
It does matter to me on equipment, if it's made in China quality isn't near as good as stuff made in America or Sweden just for a couple of examples. What good would a cutter be if the frame is heavy duty but the gearbox is made out of a poor casting? The gearbox takes a beating as much as the tail wheel does.
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
9000 (A47477)
9000 (A47477)
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2014 FREIGHTLINER...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
