B-2650 Seat
/ B-2650 Seat #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
This is the second mowing season for my 2018 B2650. I've notice that the ride is much rougher than my B2620. Yesterday I looked at the two seat springs and they appear thinner and weaker than those on my B2620.
When riding over ruts/pot holes in a field it really jars my back. The B2620 did not do that! When hitting such bumps the springs bottom out. Dang!!!! I'd like to get a fix for that. Any suggestions?
Cheers,
Mike.................P.S. I only weigh 142 lbs.
/ B-2650 Seat #2
Did you try adjusting (stiffening) the seat spring tension so you don't bottom out on ruts? I'm happy with my seat but I'm less than 150#.
/ B-2650 Seat #3
Funny you should mention this.
I recently acquired a B3000 and used to have a B2150.
No doubt about it whatsoever.... the B3000 rides rougher than the B2150 did.
I expected the opposite of that. Figured the larger heavier tractor with the suspension seat would be much better... but it's not !
/ B-2650 Seat
One might ask if my tires have the correct pressure. On the B2650 the tire recommended pressure is 35 front and 20 in the rear. Whereas the recommended rear tire pressure on my B2620 is 40 psi....35 in the front (with loader). Both have R4 tires. You'd think that the B2620 would be the rough ride.
Normally I can take some hassle from just about anything. But these "jolts" are getting to me.:(
/ B-2650 Seat #5
I agree... my back was sore after cutting the grass.
/ B-2650 Seat
Thanks guys.........no loaded tires and no Backhoe. It looks like stronger spring would help. The B2620 springs are a thicker gauge it looks like to me. That seat doesn't bottom out.
Cheers,
Mike
/ B-2650 Seat #9
You have a weight adjustment on that seat.
With a backhoe on the 2650, the regular seat is replaced with a swivel base on the seat.
That is the reason I asked about a bh.
/ B-2650 Seat #10
I took the miserable backhoe turntable off and put the standard base back onto my B2650 seat.
With the backhoe, the seat is not changed, it is the mount under the seat that changes. The dealer removes the seat and mount assembly and separates them, then the seat is installed to the backhoe turntable mount and placed back on the tractor.
I asked to keep my factory suspension when I picked my tractor up, and after spending a few months with the backhoe mount I swapped back. Since I typically only use the backhoe now and again when needed I find that I can lean back and sit my rear end on the top rear edge of the seat just fine. It's not as comfortable as the flipped around backhoe position, but I use the backhoe maybe 5% of tractor time.... I would rather suffer the 5% to have the suspension 95% of the time.
/ B-2650 Seat
Murph I don't see any "weight adjustment on that seat". All I see is the standard front to back leg length adjustment. Please clarify?
Picture maybe.
Thanks
/ B-2650 Seat #12
On the standard seat, on the rear, there is a T handle that screws the dual horizontal suspension springs tighter or looser.
/ B-2650 Seat #13
Here is the T-handle
This is the seat base on the B2650.
You can see the springs in the last photo.
/ B-2650 Seat
Well slap me silly. There it is!. I guess it came with no tension on those springs. I gave the T-Handle 3 turns tighter.
This TBN site is the best...........Thanks Guys.
Mike
/ B-2650 Seat #16
/ B-2650 Seat #18
I know this much, spending 4 hours in my father in laws rutted up pasture makes you really appreciate riding in that spring instead of rebounding off of the coils from the backhoe seat. I don't I'll lever install the backhoe seat base again. I despise that worthless junk.20190524_162133.jpg20180827_163647.jpg20190519_093725.jpg20190519_100803.jpg
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2017 Ford F-150 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
Hydrapak 3pt 20' Tool Bar (A64119)
Hydrapak 3pt 20'...
(1) 30 GALLON (1) 100 GALLON OXY/ACETYLENE TANKS (A64281)
(1) 30 GALLON (1)...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
KMC 3386 (A64119)
KMC 3386 (A64119)
