Oil & Fuel Best spray multipurpose lubricant
/ Best spray multipurpose lubricant #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Like many have a shelve full of different brands and types of spray lubricants. While spending several weeks per year on the gulf coast beach in an airstream trailer have tried many to combat corrosion. Local Ace hardware had several brands catering to marine fleets. New to me was a product called Corrosion-X. This product is expensive but absolutely works the best to lube, break corrosion, prevent corrosion, anti-seize and maintain equipment. Use on farm now with great results. Saved many fasteners I thought were too rusty. Keeps metal surfaces in the shop rust free in high humidity. From blacksmithing equipment to welding bench. They fog inside commercial and military aircraft with this stuff. Best product I have found for RV, boat, farm, hunting and shop.
/ Best spray multipurpose lubricant #2
I have used Corrosion-X for many years, good stuff.
/ Best spray multipurpose lubricant #3
Corrosion-X, and Boeshield T-9 are both very good anti-corrosion products.
But .....I actually prefer the Boeshield T-9.
/ Best spray multipurpose lubricant #4
Never heard of it or noticed it at the stores that I shop. My current favorite is Fluid Film
/ Best spray multipurpose lubricant #6
Another vote for CorrosionX. I have been using it for 20 years.
/ Best spray multipurpose lubricant #8
I use an assortment of lubes depending on the equipment and the desired outcome. Do I need a dry lube, high temp, low temps, what metal, plastic, lubricity vs penetration, protection against elements, and how gummy can the lube be? I like having options!:2cents:
/ Best spray multipurpose lubricant #9
I think pretty much anything works. It's when you use nothing, that you have a problem. People have trouble getting out unlubricated fasteners, then go all overboard with NEVER SEIZE. A little dab of any old grease would have prevented the problem.
/ Best spray multipurpose lubricant #10
Where are your buying your Boeshield?
/ Best spray multipurpose lubricant #11
Boeshield, as it's name would imply, is an anti corrosion product developed by Boeing for aircraft corrosion protection.
It is not actually a consumer product, but is an industrial quality product.
Industrial products are often considered to be superior to consumer grade products.
Sort of like Kroil. Can't buy that just anywhere either, but it is a superior, industrial quality, penetrant.
Boeshield is available on Amazon, and Newegg.com
/ Best spray multipurpose lubricant #12
:thumbsup:
I also take into consideration what affects any particular lubricant has on different materials located next to what needs lubricating.
When it really come down to it, what's the best multipurpose lubricant is just like what's the best engine oil, hydraulic oil, etc. and is mostly a matter of personal opinion.
/ Best spray multipurpose lubricant #13
Fluid Film for corrosion prevention, but I might go to Woolwax for my next undercoating.
/ Best spray multipurpose lubricant #14
Seems WD-40 started a market for light weight, multi-purpose lubricants that are now sold most everywhere under varying labels. I find that that type lubricant doesn't do what I want done most of the time. I find myself using the PB Blaster penetrating oil for most all my quick lube jobs that involve metal. It stays the course.
/ Best spray multipurpose lubricant #15
I also use Boeshield. Mostly use on my woodworking tools such as table saw, jointer, etc., but also use it on my tractor. I like it best of the lubricant/protectors. It is a bit expensive, but very effective. Ever try getting rust marks off of a cast iron table saw top? Not fun, i.e. impossible.
As Industrial Toys said though, anything beats nothing every time.
/ Best spray multipurpose lubricant #16
I'm partial to PB myself, but it depends on the job. WD is fine for squeaky door hinges, etc. and is less messy.
Curiously, does anyone sell those little plastic straws separately? It's always the first thing that gets lost.
/ Best spray multipurpose lubricant #17
∆ I found that not all straws are the same diameter.. Just don't fit sometimes...!
/ Best spray multipurpose lubricant #18
They do well straws on Amazon. And they're kinda saying they're all the same...:confused3:
Have a cup on the shop shelf that stores used nozzles and straws from empty spray cans.
My 3’x5’ steel plate welding bench is central and most used surface in the shop. Wiping with the smallest amount of Corrosion-X keeps it rust free and all the various clamps, hold downs and bolts. From lug nuts, spark plugs, stainless fasteners that tend to gall, to equipment that has to be rebuilt, maintained or cleaned every ten years it makes a difference. Boe shield T-9 is similar product that works very well too.
Oil is cheaper than metal. Using the best usually cost less in the long run. Little bit of prevention saves lots of time and money later. Make it easy on the next guy doing maintenance/repairs. I’m usually the next guy.
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
EXMARK ARS180KA21 WALK BEHIND AERATOR (A63291)
EXMARK ARS180KA21...
2021 Scout 210 Dorado 21ft Boat w 18ft S/A Boat Trailer (A61574)
2021 Scout 210...
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
