CK front axle pivot grease
   / CK front axle pivot grease #11
Aren't these supposed to get greased every 50 hours?
In any case, try removing and cleaning out the zerk fitting (use a fine pick) and see if that lets the grease go in. The threads on these fittings are not common (BSP as I recall) and hard to find locally except at a Kioti dealer.
   / CK front axle pivot grease #12
thread size is 1/8 28 BSPT
   / CK front axle pivot grease #13
Of course, I checked the zerk first. It does indeed have 28 tpi, but it seems to be parallel,
not tapered, so 1/8-28 BSP, type G. I have not dealt with that thread before. My zerk collection
has no such fine-thread units.
The zerk has marks on the nipple from my grease gun (Lincoln 14.4V) getting maxed out. These
are high quality zerks and I have never broken one on my Kioti. I have broken many of them on
my Bulgarian backhoe, so replacing them is something I am used to doing. Anyway, it flows
grease very well.
I have also replaced the axle pivot on a couple of ex-rental Deeres, and it was not easy. The CK30's
pivot looks to be beefier.
   / CK front axle pivot grease #14
My pivot has a grease zerk both front and rear. The rear zerk, at times, has been a PITA - as far as accepting grease. I unloaded the front axle by rotating the bucket and, by golly, that rear zerk took grease just fine.
   / CK front axle pivot grease #15
I take that back: there seems to be a slight taper to the zerk threads, and it is brass.
Regardless, I drove the tractor over to my workshop the other day to get to the bottom of this.
I lifted the front end up with the loader, and the axle now pivots easily! No wobble, either.
So, now I go to test if the front zerk will take grease. It takes a couple pumps from the gun,
then stops. No more grease. So I reach over (without removing the grease gun) and the axle
is now hard to pivot again. I have to stand on the wheel to make it move, just like before. So
I push it up and down several times to see if the internal grease pressure changes, and I
can see no apparent change to the resistance of the pivot.
So then I pull off the grease gun, and I can actually see grease, under pressure, slowly squirting out
around the zerk's threads. I had not tightened the zerk back up very well, apparently, after removing
it for inspection previously.
As the pressure dropped, the axle got easy to pivot again.
So, pressurizing the front pivot grease fitting causes the front axle pivot to be resistive. Anybody ever
see that before?
   / CK front axle pivot grease #16
see that before?
When you grease the front pivot, the grease fills up the small space between the axle pivot pin and the housing in which the pin pivots inside of. There is also a lip and dust seal that keeps the grease in and dust out of the pivot. That lip seal is preventing the grease from coming out, as it should. So when you pressure up that zerk, and the void is full of grease already, and the grease cannot escape, the pressure pushes the axle rearward, into the rear pivot pin, causing the axle to be stiff. Eventually that lip seal will wear enough to allow grease to push out more easily.
   / CK front axle pivot grease #17
Old thread, ...but I'll see if anyone is still listening. I heard my NX again today, and replaced zerks that weren't cooperating. The rear carrier for the front axle was one of these. Anyway, after zerk replacement, I put at least 30 pumps of grease in and don't see it escaping anywhere. Where is it going? Is it just going somewhere that I can't see? I can't imagine that it wouldn't be full after that many pumps.
   / CK front axle pivot grease #18
I have never opened up a front axle pivot on any Kioti, tho I should probably open mine. Other brands sometimes have a big cavity in there, and that is where the grease goes. My first Kubota was like that. My JDs did not, IIRC.
   / CK front axle pivot grease #19
Agree, that sure doesn't sound right. Are you certain your grease gun is actually delivering? I have several, and grabbed one the other day to grease a PTO shaft knuckle on a friend's manure spreader. After ten or so pumps I realized I'd picked up one with a spent cartridge. :ashamed:
   / CK front axle pivot grease #20
Yep, my Kubota is like that. There is actually a plug to be removed before lubricating the front axle pivot joint. Per manual, remove the plug and pump in grease until it starts to come out of the hole. Then reinstall the plug.
I can till you, although it had some grease in it from the factory, That cavity wasn't "filled" like the owner's manual called for. It took many pumps from the grease gun before I saw grease coming out the unplugged side port.
UNUSED FUTURE SB05 MINI HYD BREAKER (A57193)
UNUSED FUTURE SB05...
Cushman Electric Cart (A55851)
Cushman Electric...
2006 Isuzu NPR-HD Landscape Dump Truck (A53422)
2006 Isuzu NPR-HD...
golf cart electric (A55787)
golf cart electric...
2016 Dodge Caravan SXT Van (A55853)
2016 Dodge Caravan...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
