Disc harrow or bush hog
/ Disc harrow or bush hog #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I live in the desert and due to our continuing drought (until this year), there has been little native growth. This year due to unusual rain, the desert turned green and the weeds grew like crazy. It's like a carpet out there. Then the rain ended and the heat came and everything dried up to a nice grey color.
My main concern is wildfire. The dry brush will remain this way through the end of the year and the next rainy season. It is a disaster waiting to happen.
My question is which would be better to reduce the fuel potential, a disc harrow or a bush hog. The vast majority is light brush less than 24" high. I will be pulling either with my 30HP B7800.
/ Disc harrow or bush hog #2
I think either one will do the trick of reducing wildfire fuel. Bush hog will take down and kill vegetation more completely, but a disc harrow will work faster. How much land are you working?
/ Disc harrow or bush hog #3
If you want to bush hog the majority of it that would be fine. I would take a disc and grind everything down for a couple of rounds to make a fire lane. We disk around our hay and Some land that is in trees every year to make a fire lane. A few wildlife areas near us use a dozer to make a fire lane when they do controlled burns every few years and after a few weeks you would never know it was a controlled burn. It comes back just as pretty and green as it could be.
/ Disc harrow or bush hog #4
A brush hog seems like it would stir up a lot of sand / Dust
/ Disc harrow or bush hog #5
Many places use an offset disc pulled by a dozer to create fire lanes. They pull hard but will really do a number on grass and light brush. I'd vote for the disc with notched blades.
/ Disc harrow or bush hog #7
I guess if you can swing it, I would do both. First brush hog the whole place, then disc a couple of passes around the border of your property line.
/ Disc harrow or bush hog #8
Disk is a " No Brainer " type tool . Although some thought is required while using it , a lot less is needed versus pulling a brush hog . I have both and the disk is more like " Drop it in the ground and look were you are going to not hit anything " . The mower requires a lot of attention both looking forward and back , to avoid hitting something / running over something .
Fred H.
/ Disc harrow or bush hog #9
Is it sandy soil that you will be cutting? I have always been concerned about running my BH over sand or dirt for extended periods of time thinking it would damage the bearings and ruin the blades. Maybe that isn't really a concern.
/ Disc harrow or bush hog #10
If you just bush hog the weeds, they are still there, but in a more compact form. I would disc it to bury as much as possible.
Bruce
/ Disc harrow or bush hog #11
I can't speak for your situation but around here, before the county instigated (great idea) burn ban, farmers would burn off their (wheat mainly) fields to clear them for the next crop. They would take a disc harrow and make a couple of laps around the perimeter of the field turning up raw soil for a distance of about 25 feet and burn away......course they probably had a tractor sitting with the disc they used to do the field in the first place and will be back on the field with it when the fire extinguishes.
For me, you may get better results, hogging first to chop the crop into small pieces that will allow the disc to better turn it under...would depend on the length of the stems and durability....ala if the disc blades could cut the stems as they are covered so that the discs could sink deep enough to get some dirt to cover the crop.
/ Disc harrow or bush hog #12
A strip of mowed and condensed layer of dry material from a BH will not slow a fire. I'd use a disk to get rid of the dry fuel.
/ Disc harrow or bush hog #13
I vote for neither and or both. A Brush Hog will not remove the fuel. With a "carpet" of vegetation a disk will not properly turn the soil over.
A disk ripper is the perfect tool for this. It has a row of disk blades to cut up the dead vegetation and then has ripper teeth that will turn some of the soil on top of the vegetation.
Short of that I'd use a plow, particularly a chisel plow (sometimes refereed to as a cultivator) which will turn some of the soil over to minimize the fuel source and leave some vegetation on top to minimize erosion.
Brush hogging first will make it easier for whatever tillage equipment you can find to turn the soil and bury some of the fuel.
/ Disc harrow or bush hog #15
Roundup , disc .
He doesn't need roundup, the foliage is already dead from drought as he mentioned in the first post.
If you have the equipment, bushhog it then disc it in. A disc will do the job by itself but may take several passes to knock down larger bushes. As already mentioned, just bush hogging it wont get rid of the flammable material.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 JOHN DEERE 333G SKID STEER (A62129)
2020 JOHN DEERE...
2213 (A62131)
2213 (A62131)
5ft. Wooden Native American Statue (A61569)
5ft. Wooden Native...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
