Possible sticky valve?
/ Possible sticky valve? #1
jmurphy2007
Member
L3901, BX23S
Just sold 2004 BX23 with 1150 hours. All fluids and filters changed approximately every 100 hours (once a year). Demonstrated machine with no issues. My brother calls me and tells me that some of the hydraulic functions don't work. Pivoting the front bucket works (left right function on stick. Bucket raises but will not go down unless you float it. Sounds like it is straining if you try to lower it using pressure. Backhoe bucket function works, but arm will not extend. Sitting on seat as if you were using backhoe you can move arm to the right but not the left. I have taken unbelievable care of this machine I'm at a loss. Any help would be greatly appreciated.
/ Possible sticky valve? #2
My guess is one of the hydro quick disconnects came loose in transport. Disconnect and reconnect. Sounds like the relief valve is kicking in because it can’t flow rather than the hydraulics straining. Simple solutions first.
/ Possible sticky valve? #3
Yep!!
/ Possible sticky valve? #4
Make sure your 3PH control valve is not in the up or raise position (should be down). My B2320 FEL will not lower but will tilt the bucket when valve is on raise.
It was the 3PH in the raise position. Thanks so much. My brother needs to get used to operating the tractor.
2011 PJ Trailer T/A Tilt Trailer (A61569)
2011 PJ Trailer...
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK52CJ75416 (A61165)
2002 Freightliner...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
