Kubota L3940 Hydraulic issue
   / Kubota L3940 Hydraulic issue #1
1586
Member
Have a 3940 with 1100hrs. Bought new in Jan 2008. Hydraulics serviced every 2-years with new oil and filters. Last time was Super UDT2 in Aug 2017. Starting a month ago when starting tractor when lifting loader it wouldn't immediately lift. Took a second or so. Now recently if you go right to take off it takes a second for the hydro to get oil. Didn't know if these had a suction screen or if I should change the filters or if there is a charge pump getting week? All functions are 100% normal after the second or so hesitation. I put 90% of the hours on it so don't notice anything different.
   / Kubota L3940 Hydraulic issue #2
My SWAG- sounds like it’s bleeding the pressure off/losing intake fluid when it sits for a bit.
Does the same thing happen if you try to lift the 3 pt?
   / Kubota L3940 Hydraulic issue #3
I looked at the WSM for the previous model, L3830. With 1100 hrs, I would not expect any wear issues.
In your profile you do not indicate where you live. In cold weather Kubota recommends some warm up time before use for the hydraulics.
When you changed the oil and filter for the hydraulics, did you use a Kubota filter?
Does your tractor have the tandem hydraulic pump. One half feeds the power steering and the other the rest of the tractor?
Does the power steering work immediately?
The tractor's hydraulics are complicated, more so than many, and are not for those without the proper flow and test equipment.
Dave M7040
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2025 BOBCAT ZT7000 MOWER (A59905)
2025 BOBCAT ZT7000...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2024 MECO M-Y 4-Passenger Electric Car (A59231)
2024 MECO M-Y...
