1042 kw
/ 1042 kw #1
ktm513
mf 135
My cub 1042 kw wont stay running under a load.
Good fuel and cap off, and cked for spark.will run for ever with no blades running but wit blade. And high rpm may run a minute or 5 minutes.
Also the tube at the top of the fuel tank, where does it go??
/ 1042 kw #2
From what I can find your 1042 comes with a single cylinder Kohler Courage engine.
Most of the time the problem lies in the emulsion tube which is located under the main jet. It has tiny passages which often need to be unplugged using a small strand of wire.
Removing the main jet without damaging its slot is critical.
Do not use just any old screw driver. Find one with a series of replaceable tips.
This one from Home Depot for $20 is what I have in mind.
https://www.homedepot.com/p/Husky-Ratcheting-Screwdriver-Set-40-Piece-236360400/204364658
By hand, find the biggest, fattest, flat bit that will just fit in the main jet slot.
As you try and unscrew the main jet, keep a lot of downward pressure to keep the bit firmly in the jet slot.
With the main jet removed the emulsion tube should just fall out, perhaps with a small tap.
Dave M7040
/ 1042 kw #3
KTM,
What exactly happens when your engine is under load?
Does is stop completely? Or does it sputter and stumble or what?
Richard
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
