Building a Horse Run In Shelter
   / Building a Horse Run In Shelter #1
Atlas2015
Farmtrak 60
Hello,
I am building a 16 x 30 lean to horse run in shelter and I am using (6) 6 x 6 post as load bearing post and (6) 4 x 4 as non load bearing post. 16 feet lean to steel trusses on the 6 load bearing post along with 2 x 6 purlins that go on the steel trusses. My question is: Can I install a shingle roof instead of a metal roof with the steel trusses? I have all the materials to build a shingled roof and I hate to build a metal roof since I have shingled every other structure on my property, plus my horses will run out of it at the sound of rain here in central Florida. Thanks.
   / Building a Horse Run In Shelter #2
...plus my horses will run out of it at the sound of rain here in central Florida. Thanks.
A little off topic, but when I had my last pole building built, it came with that "bubble wrap" insulation on all walls and under the roof deck. I must say that it does a pretty good job of attenuating the sound of rain. My other 2 steel buildings have none, and you can't even hold a conversation in them while it's raining hard, but the new one with the insulation is quite tolerable. The side facing in is white, so it also brightens up the interior.
   / Building a Horse Run In Shelter #3
I don't see why you can't do a shingled roof. I assume you will use plywood sheathing attached to the purlins for yor roof decking. If you are doing metal siding then consider a slight overhang on all applicable sides so that you can use J-channel at the top to secure the top edge of the metal panels.
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
