3 pt hitch lowering knob stuck
   / 3 pt hitch lowering knob stuck #1
dlabrie
Gold Member
Campton, NH
Kubota B2910
I went to loosen up my 3pt hitch lowering pressure and I couldn't turn the knob. I ended up using a pipe wrench to turn it. Is there a way to free it up?
Thanks
B2910 hsd
   / 3 pt hitch lowering knob stuck #2
is there a lock nut on the shaft"?
I don't know. The knob connects to a shaft that goes through the frame of the tractor. I haven't had any problem with it in 18 years of use.
   / 3 pt hitch lowering knob stuck #4
I had to do this on a tractor I bought. First, make really sure what way it needs to go. On mine, the 3 point dropped really fast, so I knew it was fully open. I used a pair of channelocks on the upper part of the thread just below the knob and my hand on the knob. I moved it clockwise to close. It moved right away and was easy from then on...was jammed fully open. Works good now.
Good Luck
Good Luck
I was able to move it with a pipe wrench but it didn't loosen up any. Maybe I need to work it some more,
   / 3 pt hitch lowering knob stuck #6
Squirt some lube down around the shaft and let it sit for a while. The knob on my L3200 had seized up after I hadn't used it in a long time and I couldn't turn it in either direction. I soaked it with some lube and tried again a few days later and was able to turn it by hand.
Thanks, I'll give that a shot.
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
PALLET OF MISC (A58374)
PALLET OF MISC...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
