3 pt hitch lowering knob stuck
   / 3 pt hitch lowering knob stuck #1
dlabrie
Gold Member
Campton, NH
Kubota B2910
I went to loosen up my 3pt hitch lowering pressure and I couldn't turn the knob. I ended up using a pipe wrench to turn it. Is there a way to free it up?
Thanks
B2910 hsd
   / 3 pt hitch lowering knob stuck #2
is there a lock nut on the shaft"?
I don't know. The knob connects to a shaft that goes through the frame of the tractor. I haven't had any problem with it in 18 years of use.
   / 3 pt hitch lowering knob stuck #4
I had to do this on a tractor I bought. First, make really sure what way it needs to go. On mine, the 3 point dropped really fast, so I knew it was fully open. I used a pair of channelocks on the upper part of the thread just below the knob and my hand on the knob. I moved it clockwise to close. It moved right away and was easy from then on...was jammed fully open. Works good now.
Good Luck
Good Luck
I was able to move it with a pipe wrench but it didn't loosen up any. Maybe I need to work it some more,
   / 3 pt hitch lowering knob stuck #6
Squirt some lube down around the shaft and let it sit for a while. The knob on my L3200 had seized up after I hadn't used it in a long time and I couldn't turn it in either direction. I soaked it with some lube and tried again a few days later and was able to turn it by hand.
Thanks, I'll give that a shot.
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2014 Gravely 60" Zero Turn Commercial Mower (A55973)
2014 Gravely 60"...
2016 Ford F-150 XLT Pickup Truck, VIN: 1FTEX1EP4GFD61185, Extended Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2016 Ford F-150...
2011 UTILITY 53FT REEFER TRAILER (A58017)
2011 UTILITY 53FT...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
