Dealership Service Call
/ Dealership Service Call #1
Avenger
North Idaho
LS XR4145C
On Sunday evening I was up in the forest doing some loader work on a rather steep hill. After dumping my third scoop of dirt, the tractor suddenly and without warning idled down from 2500rpm and shut itself off. No lights or codes. I attempted to restart it, but all it did was crank over. I did the basic troubleshooting measures: it has 2/3 tank of fuel, engine oil is good (I am good at checking it before starting it daily, but checked it again after it shut off, still good), coolant was good, air filter is good, nothing leaking from underneath, no water in fuel, fuses look good, etc.
I hooked up my OBDII scanner and read no codes.
At a loss, I figured I'd call the dealership on Monday and see if someone was available to come out. I figured they have a better computer than I do for talking to these things and it is probably some weird computer glitch or sensor malfunction since I cannot find anything obvious. The service mechanic was not able to come out until Tuesday morning (today).
The mechanic showed up promptly and we went to work, out in the forest, up on the side of a hill, in the sticks. Spend 2 hours troubleshooting it. His computer, while very cool with very neat tricks, did nothing for us. It did say that the fuel rail pressure was a bit low, but within tolerance. However he did figure it was a fuel delivery problem. Disconnected the lines from the fuel filter thinking that somehow the engine lost prime and sucked air... somehow. He was thinking that maybe the fuel pump died or something. He hooked up a little 12v fuel pump in between the filter and the tank and turned it on. Nothing came out. So he disconnect the output side and still nothing came out.
At this point I was starting to suspect that maybe it was a faulty fuel gauge and that I ran it outta diesel. The mechanic looked under the tractor and noticed a steady flow of diesel coming from the fuel line at the tank and falling to the ground! When he moved the fuel line, it opened up a very small gash just large enough to allow fuel to flow.
Apparently I had hit a rock or stick or something and made a small hole in the fuel line right at the tank. It wasnt enough for fuel to leak out, but was large enough to allow air to be sucked it. The engine lost prime and acted as if it run outta fuel. I exacerbated the issue when I drained some fuel form the filter checking for water and pumped it back up, sucking yet more air into the system. It took about 5 minutes to fix the line (cut off the torn end, stick it back on the nipple and tighten a hose clamp), and bleed the lines with his 12v pump.
I am not sure what the service call is going to cost me yet, but having someone come out and get a second set of eyes on it, find, and fix the issue, I am just happy its running again. Hopefully it wont cost me too much.
I am a bit embarrassed by how simple it was and the fact that I did not find the issue myself, but you live and learn. Besides, if this was a warranty issue, I might have caused something to void the warranty. The tractor is only a year old, 4 more years on that warranty.
I am also considering making a skid plate for the bottom of the tractor. There is much more than just a fuel line under there. Steel hydraulic lines, fuel lines, fuel tank, rubber hydraulic lines, etc. Thoughts? Has anyone made one before? I was thinking something like 1/4in steel plate bolted to the loader frame with a small drain hole for moisture. A front lip that could act like a ski or something, for going up and over instead of though.
Where I live in the forest with stumps, stick, rocks, mud, etc and with what I do, logging, making roads, removing stumps, digging rocks, etc I think it would be a wise idea to put a skid plate on any tractor.
Anyway, just wanted to update you all. Nothing wrong with the tractor as far as major issues, just me running my tractor like it wasn't supposed to be run.
/ Dealership Service Call #2
Good to know and glad you and the mechanic found and fixed the problem. I don't expect mine to start having problems but my warranty just ran out. 5 years without so much as a hiccup. I'm still keeping PDI (physical damage ins.) insurance on mine just in case any glass breaks, fire, theft, etc.
/ Dealership Service Call #3
Oddly enough, I had a car do exactly the same thing. Just up and died on me (on a hill too). I was able to coast it to a stop along side the road. After I cranked it a few times and nothing happened, I called a wrecker. They loaded up and dropped my off at home on their way to the shop. We took a few minutes to talk through the problem. He got in and tried to start it. That's when I noticed gas spraying out onto the rollback bed. Line had come loose right at the tank/pump output. He had to take it to the shop to get the right tools and clamps, but had it fixed and back to me that afternoon.
If your dealer is reasonable, I wouldn't expect more than 2-3 hours labor including the travel time. It's also possible that a 'defective fuel line" could be a warranty repair. They shouldn't be that sensitive in your case.
/ Dealership Service Call #4
I have the same tractor and built a skid plate for mine. I did not like how the fuel line and the tank are unprotected. It痴 already saved me from problems.
/ Dealership Service Call #5
I have the same tractor and built a skid plate for mine. I did not like how the fuel line and the tank are unprotected. It逞エ already saved me from problems.
I知 not sure how to post pics, but I have a couple.
I'd love to see them! There is a button at the top of the reply box, for me it is 3rd from the right, shows a small photo of a tree. If you hover your mouse over it, it shows "Insert Image"
/ Dealership Service Call #7
I’m doing it on my phone, hop this works. A11AF8A3-1C3C-4D70-85B8-D218BBBB98D4.jpegB8A5BBF7-6483-4AB1-94A3-717C28A9922B.jpeg
That does work! That is exactly what I am thinking about doing. Thank you!
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Firestone 14.9 x 24 Tire, Unused (A66408)
Firestone 14.9 x...
