ck30 lower radiator hose
/ ck30 lower radiator hose #1
MWB1564
Pacific Northwest
2007 CK30HST
I've got a 2007 ck30 hose that I accidentally punctured and need to replace. Its the one that goes from the bottom right corner of the radiator to the engine block, is about 12" long, and has about a 1/2" i.d. I've tried to find one online with no luck and have no local dealers. Does anyone know a source for this? I'm not even sure what you call it but it carries coolant from the radiator and it has a braided material on the outside of it. Thanks for your help.
/ ck30 lower radiator hose #3
The local Ace Hardware carries clear plastic, high temperature hose with nylon braid.
/ ck30 lower radiator hose #5
I had looked on their site before but didn't see it because it was listed under the subgroup "chassis" instead of what I thought would be "engine". I'm going to order it now. Thanks for your help.
It's been a year or so since I ordered from MEI but if you have any parts questions, Robert in their parts department is very knowledgeable.
/ ck30 lower radiator hose #6
There are many Kioti parts listed under counter-intuitive headings. It just takes persistence. Otherwise the online parts catalogs are very useful. Bu the way, prices vary from dealer to dealer but MIE is usually has the best price but shipping costs.
/ ck30 lower radiator hose #7
Just get a piece of appropriate hose at the local parts store/ag supply store/industrial supply store/hardware store...
It will likely be cheaper and you will likely have a choice of qualities of hose.
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
2005 John Deere 210LE 84HP Loader Utility Tractor with Box Blade (A61567)
2005 John Deere...
2013 Ford F-250 Ext. Cab Pickup Truck (A61568)
2013 Ford F-250...
2019 Mitsubishi Mirage G4 Sedan (A61569)
2019 Mitsubishi...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2011 Mack GU713 Granite Dump Truck, VIN # 1M2AX07YXBM010053 (A61165)
2011 Mack GU713...
