Loader JD 3039R and H165 FEL
   / JD 3039R and H165 FEL #1
Bfavro
JD 3039, 727A, L130
I have a 2015 John Deere 3039R and the H165 loader. I noticed the other day when lifting loads of gravel for a project that the loader masts are lifting off the mounting frames on both sides with a full load. I was able to put the bucket in 20 degree position (attachment procedure) and heard the masts pop back onto the mounting frames and end plates. I am still seeing a bit of lift on heavy loads that I am not comfortable with. Seems to be one side more than the other. Nothing unusual about the weight, lifted this 1 1/4" processed gravel material at this weight many times before. I have proper ballast and loaded rear tires. The machine is fairly new to me so I have not taken the FEL on/off before. Manual only seems to talk about checking torque on the frame and loader bolts. Is there some adjustment that I should be looking into on this?
   / JD 3039R and H165 FEL #2
I assume it is a removable loader? I would take it off a put it back on to make sure it is installed correctly. Make sure the latches are hooked and locked correctly.
I performed a 50hr maintenance check on the loader, which is hadn't yet, and the latch screws definitely needed some adjustments. Going to test her out today and spread some loam, so we'll see.
   / JD 3039R and H165 FEL #4
For sure the latch screws. BTDT. Tighten those up and you should be good to go.
That was it. Good as new! Suppose now I should check the torque on the loader / frame bolts.
   / JD 3039R and H165 FEL #6
I might have the same issue. By any chance, do you a picture to show me what we are talking about when we say latch? Thank you.
2003 JOHN DEERE 110 BACKHOE (A52707)
2003 JOHN DEERE...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55314)
2011 New Holland...
SKIDDED FUEL TANK (A55745)
SKIDDED FUEL TANK...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
