John Deere 513 rotary cutter
/ John Deere 513 rotary cutter #1
shock
Ford 2910
Anyone know what size the snap ring is for the top seal? I'd like to pick up a generic but don't know the size.
/ John Deere 513 rotary cutter #2
I tried to google it without any results.. thats pretty pricey for a snap ring as well..
good luck
/ John Deere 513 rotary cutter #4
Take the seal or better yet the old snap ring to a hardware store and match it up. If you use the seal for the size get it a little bit larger. Best to use the old snap ring or a piece of it to get the thickness.
/ John Deere 513 rotary cutter #5
Here's the spec's you requested.
/ John Deere 513 rotary cutter #6
Which key from the drawing is that snap ring? I was thinking he wants key 24, but he never responded. Key 24 is an internal snap ring. Your spec is for an external/shaft snap ring.
Also the top cover bolts are metric, so I would think the snap ring will be metric.
/ John Deere 513 rotary cutter #7
Zebrafive
OOPS what was I thinking about. Thanks for correcting me. Spec's for snap ring(key 15) are shown below.
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
(APPROX. 450')LOT OF LATCH LOCK 6" IRRIGATION PIPE (A64278)
(APPROX. 450')LOT...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
