piaffepony
- Joined
- Feb 27, 2017
- Messages
- 127
- Location
- Ft. Worth
- Tractor
- JD 5055D, David Brown1212, NH LS170, JD Gator 850D
120x240 outdoor arena. 6” wood posts for RAMM flex fence and railroad ties along the bottom to keep footing contained.
Long story short, I’m replacing a lot of posts and redoing the drainage as one corner is badly eroded; exposing the whole height of the concrete footing and 80% around of the corner post. It has tweaked the whole corner bracing assembly (crooked AF!) so all 5 posts involved will need to be worked on. That corner is built up about 3-4’!
I put in a French drain along the whole 120’ low end with a dry-well/catch basin in the giant eroded whole and will be putting overflow spouts on it leading out and away from the posts.
So my question is:
How should I go about installing the new corner post since there is no soil or anything there yet? I guess I could fill it in first, but that would require a retaining wall and even then, the soil won’t be very packed and I planned on most of that corner being filled in with gravel and the outside of the corner with large rocks from the pasture.
If I try to set a pier and backfill around it, what’s the best way to keep it level, plumb and in line with the other fence posts since I will have to move and reset the other 4 supporting posts along with it?
So my question is:
(lol sorry I couldn’t help myself)
Any decent diy sonotube substitutes that would work?
