Ford 3000 Group 8-3 Control Valve with float Series 735 model #19-526
   / Ford 3000 Group 8-3 Control Valve with float Series 735 model #19-526 #1
papabear24
Ford/3000
The control valve was leaking around the spools and I assumed is was on O-Ring replacement, until I tore it apart. Well the spools were junk, pretty scored. My question is has anyone replaced the control valve with a more modern type control valve without to many modifications? If so, what was the brand, type, model etc.? The Tractor is a 1969 Ford 3000 with a series 735 Model 19-526 loader. The control valve is a Group 8-3 with float. Any information is greatly appreciated.
   / Ford 3000 Group 8-3 Control Valve with float Series 735 model #19-526 #2
Start with a most basic question...... how many hoses on your loader valve. 6 or 7. Count carefully as your answer is critical.
Do you have power steering and if yes, does it have its own pump?
If the loader valve has 6 hoses, then likely it is independent of the rest of the hydraulics...
If the loader has 7 hoses, then likely it has a power beyond feature and the 7th hose is feeding the 3 pt hitch and any rear remotes.
Look over the 2 pages of this literature from Prince hydraulics which gives you some illustrations of the valve parts making up the addition of power beyond to a standard valve.
http://www.princehyd.com/Portals/0/valves/LvtInstS.pdf
A modern joystick loader valve will work but first do not order a valve with a high flow rating. Your tractor system pump is a 5 gpm one. Too big a valve and you loose precision control of the loader.
I have found the tech purchasing advice from Cross Manufacturing to be excellent compared to buying a random valve off the shelf based only on price. They can explain the features they can provide on a simple loader valve.
This link is to their DV series:
Hydraulic Directional Control Valves Model DV | Cross
Their phone number in Kansas is 620-324-5525. Ask for tech support and discuss your application.
Dave M7040
RoGator RG1100C (A51039)
RoGator RG1100C...
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
