Towing Capabilty
/ Towing Capabilty #1
mallenwase
no
Which truck has the capability to tow 3 tractors? I am a towing driver in a Rite Way Towing & Recovery. have to do this task next week. does anybody know?
/ Towing Capabilty #2
Tractors can weigh from 2000 pounds to well over 10000 pounds. I think we need more information. I think you would be safe with a Kenworth and a lowboy trailer.
/ Towing Capabilty #3
What do these tractors weigh? They can be little 1900 lb SCUT garden tractors or 25,000 lb agriculture machines. Obviously 3 of SCUTs is not the same challenge as 3 large agricultural or construction machines. In other words, your question asked, as provided, is incomplete and utter trash. How wide, long and tall are each? I am already assuming that you are envisioning a full sized tractor trailer.... is that true?
Now... if you provide honest useable information and form the question in a way that suggests that you know what your actually asking, and that you actually want helpful responses...... The collective brain trust of TBN will surely come in and provide you with more information than you need.
/ Towing Capabilty #4
The key to everything here is weight... How heavy are these machines.... MY SCUT weighs in around 1600 lbs and I transport on 7000 GVW car carrier behind "heavy half ton" pickup.... Your situation may be wildly different....
Dale
/ Towing Capabilty #5
A Honda Ridgeline should do fine, just put 3 trailers behind it. :dumptruck::tractor::tractor::tractor::ambulance:
If I ever need anything towed or hauled I will be sure not to use Rite Way Towing and Recovery.
/ Towing Capabilty #6
F150 - just make 3 trips :)
Even a smallish tractor without a loader is a little over 8' long so would need a pretty long trailer. I can't see 2 of anything (unless garden tractors or something really small) on even a largish rollback.
For reference, this is my previous one (small) on a 16' trailer and the rollback that brought my current one (medium).
/ Towing Capabilty #7
That rollback looks eerily familiar. :thumbsup:
/ Towing Capabilty #8
My Dakotas pulled anything I ever asked of them.
BTW, I would avoid that little rickety bamboo bridge, right on the outskirts of Mumbai.
/ Towing Capabilty #10
Toyota Tundra. It can tow the space shuttle.
/ Towing Capabilty #11
I just rode with my neighbor to pick up an 8500 lb. forklift he bought.
Forklift + trailer weighed about 11,500+ lbs.
His Tundra towed it (65 mph - flat terrain) easily for 250 miles.
/ Towing Capabilty #12
three tractors at once? or three different sized tractors? i dont know about that rest of the guys here but my tarot cards are not helping much - throw us a little more info
/ Towing Capabilty #13
I guess the OP doesn't know what size tractors he needs to haul so I'll have to go with BillyBees answer about the KW and lowboy.
/ Towing Capabilty #14
i believe the kenworth will get it done!!!
24220 (A56859)
24220 (A56859)
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
(2) TRAILER RAMPS (A62131)
(2) TRAILER RAMPS...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
17395SFL (A61568)
17395SFL (A61568)
