Overfilled with hydraulic oil - should I drain the excess?
   / Overfilled with hydraulic oil - should I drain the excess? #11
My front axle has a dipstick just like the hydro dipstick.:)
   / Overfilled with hydraulic oil - should I drain the excess? #12
That's good! Mine is a stubby tapered rectangle orange plastic half covered in factory paint horrible little thing :) The only way I can read it is to press it against paper or a rag and read the level as transferred. At least no harm in overfilling there - will just weep out :)
I would like it if it were same as HST one - that one is easy to read. Only issue there is the hole is small enough oil can kind of stay there from surface tension so when you pull it out it drags that out and reads like its way over full. Simply wiping & rechecking fixes that, but was :eek: first couple times.
   / Overfilled with hydraulic oil - should I drain the excess? #13
On the topic of Kioti axle and hydro dipsticks, what are y'all referring to when you say they are terrible?
I ask because my CK3510HST came new with just the barest bit of fluid evident on both of these dipsticks when checking fluid. My dealer indicated that was OK, but it seems weird to me. Is this part of the weird-ness that you are talking about? Just trying to learn my tractor... (and determine if I should top the fluid off).
Thanks!
   / Overfilled with hydraulic oil - should I drain the excess? #14
Yours are probably slightly different but there are min/max levels on the dipsticks & you should be within those ranges.
Not great pics but you can see how my F/A one is. What you can't tell from the b&w grainy pic is it is orange plastic & you can't really see clean oil on it. Also note how long the threaded area is - it's screw in to check. Compared to the hyd oil check - that's a nice dipstick that just pushes in w/o threads. And it's stainless steel and easy to see. Has notches for min/max vs scribed lines too. Just a huge difference in design between the two on same machine where one is good & the other is poor.
The engine oil is fine and typical of what one would expect for an engine oil dipstick.
   / Overfilled with hydraulic oil - should I drain the excess? #15
Both of mine are nice metal dipsticks, but neither has scribed lines on it - just a flattened area in which the high level is implied by a change from flat to round, and a low level implied by the length of the dipstick. My fluid registers just a drop at the very bottom.
I'm currently struggling with the 50-hour change-or-not-change fluids quandary. I don't want to add more fluid just yet in either case. If I change only the filters then lower fluid means less pressure and less likelihood of fluid loss during the swap. If I change fluid then obviously I don't want to waste fluid topping it off. Everything is working well, but I want to sort it out in the next week or two before I start using the tractor.
   / Overfilled with hydraulic oil - should I drain the excess? #16
Your filters don't hold all that much. No big deal adding some fluid.
I did mine @50 & my previous one as well even though that was way early. On my LS there was a noticeable decrease in HST whine. On the Kioti I noticed 0 difference from the Chevron fluid dealer used vs changing to Kubota SUDT2. I know I have good fluid in my machine, but otherwise was kind of a lot of $ for what is probably only a psychological benefit - peace of mind.
If you're having no issues, just get whatever your dealer used & add as necessary until service interval that requires change. Unless you have some reason you think a different fluid will be better - whine, cold weather performance, whatever.... Find out what your dealer used first....chances are it wasn't yellow bucket 303 or similar junk. If it's a good fluid, no reason to change it unless you just want to do it to do it. There was accumulation of swarf about 1/2 the size of pea on my drain plug magnet. Otherwise the fluid itself appeared as new - you could also do that - pull the plug, stop it with your finger, and see if your magnet has anything....
Anyway, add to both so you're in the center of that flat. Won't take much for either
   / Overfilled with hydraulic oil - should I drain the excess? #17
On my DK45 i didnt know about the drain plugs on the rear axles and i only drained the main plug. The manual didnt even show the other 2 drains or tell me i had to do it. I found out about them from another member on this site. The dip stick on mine is notched ay low and high levels.
   / Overfilled with hydraulic oil - should I drain the excess? #18
I've just had the same problem. I even used all 3 drain plugs. And that little dipstick is worthless. I tried to ease up to full and BLAM! it was overfull.
I guess I'll pull one of the little axle drain bolts and try to pull out a quart.
I wonder if I could suck it out through the fill tube. (BTW I poured the drained oil into the old pail and there wasn't even close to what the spec said capacity is.)
Everything I do one the tractor points up how crappy the manuals are.
You are right. Manuals these days velly clappy. nah so good ;)
   / Overfilled with hydraulic oil - should I drain the excess? #19
Yikes! I didn't even consider this on my NX5510!
Curious, how come when you first pull the dip stick out of the hydro does it read low and then when re-inserted and pulled it jumps up substantially? This has always puzzled me.
   / Overfilled with hydraulic oil - should I drain the excess? #20
With overfilling my concern would be damage to seals in some circuits.
Underfilling on the other hand often will cause over heating but that will show up soon enough,
Serious under filling will result in jerky hydraulics as your warning.
On my CUT the hydraulic reservoir is the transmission 'tunnel' and that never had a dipstick so when I did a major fluid replacement I mad my own dipstick once I had filled to specs. (simple painted wood affair, that works 4 me)
Pig Statue (A57149)
Pig Statue (A57149)
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
JOHN DEERE 348 SQUARE BALER (A58216)
JOHN DEERE 348...
Polaris Ranger (A57149)
Polaris Ranger...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
