LS Tractor Oil, Gas, & Air Filter Information
/ LS Tractor Oil, Gas, & Air Filter Information #321
XR4140HC owner here. My dealer told me NAPA 1516 for oil filter, which we all know is the Wix 51516. I saw another poster said they tried that and it fit but was smaller than the stock oil filter, and he is now using a Wix Oil Filter WL7426 that he says is the same size and shape as the original.
WIX WL7426 Oil Filter
Can someone confirm that one the XR4140 its the WIX 5151 for the oil filter?
Wix WL7426 is what fit mine, see attached list from Rockauto
Can anyone tell me, is this a "pick one" for the 4100 series? Seem to have 3 choices.
/ LS Tractor Oil, Gas, & Air Filter Information #322
I知 the guy who said the Wix WL7426. I searched for a long time and cross referenced the engines to another vehicle (in Korea). I first used the Wix 51516, but felt it was too small (less filtering material). I致e been happily using the WL7426 without issue on my XR4140HC. Just buy a few of them up front to save the hassle and extra shipping costs.
/ LS Tractor Oil, Gas, & Air Filter Information #323
I own a 2019 MT350E with an L3C19-T2 engine. Just turned 50 hours so I need to do oil, oil filter and hydraulic filter. Dealership wants $126 for everything and I'll install it. I'm going to look at the old filters and get a crossreference so maybe I can buy cheaper/local. Any tips as to what oil I should use?
/ LS Tractor Oil, Gas, & Air Filter Information #324
I am just over 900 hours, on my 3 services I just used the guide in the Owners manual for my R3039 Tier 3 engine. Looked at the ambient operating temperatures I would be using it in, then made sure that the Oil specs met the Manufacture guidelines and bought what was on sale.
/ LS Tractor Oil, Gas, & Air Filter Information #325
I can't find the part numbers on the current filters because they are painted black. If anyone can point me in the direction of a parts manual for a 2019 MT350E it would be greatly appreciated.
Thank you
/ LS Tractor Oil, Gas, & Air Filter Information #326
XR4140 needs a new air filter. It's there a list or chart on this thread or site ?
/ LS Tractor Oil, Gas, & Air Filter Information #327
Gang, while you're under warranty, it's really best to get these things from your dealer. Last thing you want if you have trouble is for them to deny a warranty repair based on use of the wrong filters.
/ LS Tractor Oil, Gas, & Air Filter Information #328
If LS did deny warranty because using a after market filter or any other aftermarket part they would have to prove that it caused the problem as per Magnuson–Moss Warranty Act.
/ LS Tractor Oil, Gas, & Air Filter Information #329
Anyone using Rotella HD hydraulic fluid?
Also appears Wix does not make a HST filter for an XR3135H, only the HYD filter. Also no oil filter?
/ LS Tractor Oil, Gas, & Air Filter Information #330
Just finished my 50 hr. maintenance on my MT225 EH. Here are some things I thought might be helpful to those who are about to do the same.
MT225 EH
Hydraulic Oil Filter: Luber-finer LFH8207 was a perfect fit. The manufacturer/dealer had this puppy on incredibly tight. Have a good strap wrench available. I just used a clutch style bar clamp (normally used for wood working) and just tightened it until it dented the filter and then manhandled it off. I suspect the dealer does this because of the vibration these endure, especially at idle. You will lose hydraulic fluid when you change this filter so have a few quarts available.
Air Filter: WIX 46449. No issues replacing this one.
Oil Filter: WIX Filters - 57040. Again, the OEM oil filter was way tighter than I would have expected it to be. When I removed the OEM oil filter I noticed that it was about an inch longer than the WIX filter that I bought. The WIX fit fine; and, I have had no trouble with it so far. I am going to try to find a longer filter. The OEM filter was hard enough to get to with the cheap oil filter wrenches I have, having it about an inch shorter is not going to make it any easier to do. I might try a Baldwin B1341 next time, those are about 4 inches long versus about 3.5 inches of the OEM and 2.5 inches of the WIX filter. The manual says there are two oil drain plugs on the tractor. I was only able to find one (same side as the filter). Drain plug is 17mm.
Good luck, and if you have any information to share on the MT225 tractors, please do.
/ LS Tractor Oil, Gas, & Air Filter Information #331
Is there a post with oils and filters used on the newer MT240HE/MT235HE?
I tried multiple searches and nothing came back.
/ LS Tractor Oil, Gas, & Air Filter Information #332
Assuming that many of the LS tractors likely use the same filters, it would be helpful if the original filter's numbers were listed with the aftermarket replacement. ie:
TRACTOR MODEL NUMBER - YEAR
OIL FILTER
[factory part number] - [replacement brand - replacement part number] plus notes as needed like size, fit, etc.
etc.. If that exists here, please point me to it.
/ LS Tractor Oil, Gas, & Air Filter Information #334
Originally Posted by Underdog57
2013 LS R4041H Engine - S4QL Mitsubishi Tier 3
Oil filter / OEM # 40006977 / NAPA # 1334 / WIX # 51334 / Bosch # 3310
Fuel filter / OEM # 40006997 / NAPA # 3128 / WIX # 33128
Hydraulic Filter / OEM # 40007638 / NAPA # 1715 / WIX # 51715
Hydro Transmission Filter / OEM # 40007563 / NAPA # 1551 / WIX # 51551
Inner Air Filter / OEM # 40049447 / NAPA # 2985 / WIX # 42985
Outer Air Filter / OEM # 40007575 / NAPA # 6438 / WIX # 46438
Update: The NAPA Oil filter #1064 & Wix Oil filter #5106453 would not fit my tractor. The correct oil filter for my 4041 is NAPA # 1334 or Wix # 51334 or Bosch # 3310.
These should be the Corrected numbers above ^
Maybe these will help?
/ LS Tractor Oil, Gas, & Air Filter Information #336
2019/2020 MT240HE
These are off the Invoice for the spare filters I requested from my dealer at purchase. Only the OEM is what I can verify, I'll leave the cross referenced numbers posted from above.
Oil filter / OEM # 40409065
Fuel filter / OEM # 40271228
These are what is printed on my air filters,
Inner Air Filter / OEM # Donaldson P822769
Outer Air Filter / OEM # Donaldson P822768
/ LS Tractor Oil, Gas, & Air Filter Information #337
Thanks for adding a few more data points. Interesting that my oil filter is OEM # 40318591.
I just found this: "GENUINE LS ENGINE OIL FILTER P/N 40409065(your number) REPLACES #40318591(my number)"
My OEM #s for both hydraulic filters agree with yours.
I went to the Wix website and looked up the LS MT240HE. They list the E and the HE model, but the site responds, "Sorry, but there are no filters for this vehicle in our records."
/ LS Tractor Oil, Gas, & Air Filter Information #338
A friend of mine just went to look at a new LS. The dealer told him that he had to run LS filters on it or it would void the warranty on it. The friend that he took with him was a guy that works as a sales rep for one of the bigger companies. His statement was "That was a law suit waiting to happen". I think this has already been solved in federal court. The only way to require this is for them to provide the filters. If anyone knows anything else, I would like to see it. The LS dealer is a good guy, but I think he is wrong on this.
/ LS Tractor Oil, Gas, & Air Filter Information #339
I
I believe you are correct.
The OEM oil filter costs $17 and figured it gave me a good excuse to visit my dealer. He is a good guy and has helped me out a lot. After the first oil change at 50 hrs, the manual says every 250 hrs. I change oil/filter every 100-150 hrs. Saving less than $10 dollars every 100 hours is not a priority for me.
/ LS Tractor Oil, Gas, & Air Filter Information #340
I searched but couldn’t find info for a XU 6168, does any one have the filter info for this tractor?
1993 M149A2 400 Gallon Potable S/A Water Tank Trailer (A59228)
1993 M149A2 400...
2020 INTERNATIONAL LT625 SLEEPER (A59904)
2020 INTERNATIONAL...
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
