Backhoe rpm speed
   / Backhoe rpm speed #11
I have the 2475 on a ck3510se, so not exactly the same, but I'd warn against running at lower rpm's for backhoe work. It might be more comfortable in terms of control and noise, but you'll trigger regens much much earlier. When I bought my machine new last year, my first projects were digging, and I ran between 16-1800 rpm for most of it. First regen was at only 18hrs. I bumped the rpms up to 2200, and 2nd regen was at 63 hrs. Since the tech is fairly new, and DPF's are expensive to replace, I'd rather have the longer intervals between regens. Haven't done the math to determine how much more fuel I burn at the higher rpms, but I think it's fairly minimal. Good luck with the oil leak, luckily my machine has been trouble free (so far).
I run mine around 2200-2250 rpm, and you are correct on the Regen. These motors are high rpm, clean burn tier 4. ie the higher rpm the cleaner they burn. I haven’t tested the hydraulic pressure at this rpm but I’m convinced the hoe has better digging force at this rpm range than the lower rpm.
   / Backhoe rpm speed #12
What is most important when operating a backhoe at any RPM is that operators use a little finesse on the control levers. Precise movements are more important than rapid movements. Smooth and accurate operation only comes with experience which only comes with operating hours, many of them. ;)
   / Backhoe rpm speed
You got that right! I only used mine for a few hours but the first hour was WILD!
   / Backhoe rpm speed #14
Randy did you look for the hydraulic fluid leak? It could just be a loose fitting. You probably know this but dont operate if there is a considerable leak. Check your fluid level to be sure it isnt low.
   / Backhoe rpm speed
Shop mechanic showed up and fixed it. It was a loose fitting on the bottom of the backhoe. Not sure how it happened but it was only finger tight. He topped it off with fluid and cleaned up the mess so I am good to go. Feel slightly embarrassed I didnt try to find and fix it myself. But with only 13 hours on it didnt want to be responsible for messing something up.
Superb customer service......Crossville Tractor in Crossville TN.
   / Backhoe rpm speed #16
Congrats on the timely fix! As for the question on RPM, as most indicated, it really depends on your level of control. That being said you want the highest RPMs you can control the movement at.
At low RPMs there simply is not enough hydraulic flow to operate multiple functions, but it keeps the unit from moving too quickly if your movement of the controls are not gentle enough.
At high RPM, if you can properly feather the controls, you can get three functions at once which allows you to curl the bucket while dragging the dipper in while also bringing the boom up to maintain a level cut with the bucket.
Start with the lowest RPM you feel comfortable with and work one function at a time. As you start to get the feel for the controls, you will naturally start feathering the controls to get more than one function. Once you do that and are successfully getting more than one function at a time, you can increase the RPMs to gain back some speed of operation.
A lot of care must be taken in the operation at high RPMs. Operating two functions at once will cut the speed of each function by more than half. Operating three functions will cut the speed of each by about 75%. If you are running a high enough RPM to run three functions efficiently, operating a single function will be EXTREMELY fast unless great care is taken in feathering the control very gently.
I've often said that digging a hole with a backhoe is just as tiring as digging it by hand. The only difference is it gets done faster cause you have a bigger shovel. Holding your arms and hands in a constant state of flex with the extremely tiny movements required to operate a backhoe smoothly is extremely tiring.
I use my backhoe pretty often, nearly half of the hours on my tractor were spent running the backhoe. Even running it often, it isn't a daily thing and I'm no pro (by any means), so the way I generally work with mine is I'll start the job with low RPMs while I get back into the feel of it and run the RPMs up a couple hundred at a time until I get a good pace going. I can always tell when I start getting tired, as my control over the backhoe starts to diminish and movements start getting jerky. At that point I turn the RPMs back down to finish, or call it something to finish another day.
If I had a tip to give, it would be to pay special attention to the range of motion of each joint on the unit and learn to feather each control to a stop before the full range of motion on the joint is reached. When you have mastered feathering the controls and are running more than one function, the reason becomes more apparent. If you are feathering it to get three functions and one of the functions reaches the full range of motion it can provide, the flow gets diverted into the other two functions and they will speed up. Learning to watch the functions and feathering them to a stop before reaching the end of motion helps keep you from taking a big scoop from the bottom of what should be a flat bottomed hole or knocking the side in on a trench you've dug.
Good luck!
   / Backhoe rpm speed
It is all starting to come together. Backed off the rpms to 1,900 and paid attention to how fast I was moving the controls. Even the wife said I was doing a much better job. We been on a quest to get some fruit trees planted and the backhoe has been a godsend. Getting rid of a lot of the hard, rocky, clay soil and mixing in a lot of good potting soil and manure. It sure makes a difference compared to a pick and shovel:)
   / Backhoe rpm speed #18
Another plus for @2100 rpm for regular work, slowing it slightly for precise work and full throttle for tougher jobs.
   / Backhoe rpm speed #19
On my B26, 1800-2000 RPM is a sweet spot. Increasing the RPM beyond that doesn't make it operate any faster or have any more power, it just increases motor noise. I too will throttle back to 1200-1500 for finesse work, although feathering the control levers works well also. I have close to 500 hours on mine and can do most anything at full throttle if I wanted to but why waste fuel and damage your hearing with a much louder engine noise.
Note: since I dont have to concern myself with DPF, I can operate at any speed without any issues.
   / Backhoe rpm speed #20
Unfortunately after purchasing any new machine you have to go around them with a socket set and open end wrenches and tighten things. I haven't purchased many things that didn't have something loose, There are many techs in dealerships that are just plain lazy..
E-Z-Go Workhorse Utility Cart (A55851)
E-Z-Go Workhorse...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
