Longest Original Tractor Battery Life?
   / Longest Original Tractor Battery Life? #21
non a CUT battery, but a 12 volt red top optima in my old car lasted from June 1989-april 2012.
   / Longest Original Tractor Battery Life? #22
2007 Kubota Grand L- replaced factory battery in 2017
   / Longest Original Tractor Battery Life? #23
My 2003 NH TC30 made it to 11 years on the original battery here in Maine. Tractor is used year round.
   / Longest Original Tractor Battery Life? #24
As a couple of posts above. I took out my original battery in 2006 and fitted a red top gel Optima and it is still going strong. I gave the original to my lad for his ute. He is on his 3rd one since then.
I wish I could say the same for my Honda battery... 2008 and needs a 4th battery very soon. Time for a new car I think.
   / Longest Original Tractor Battery Life? #25
I wore my original battery down a few weeks ago in very cold (-10F) temps. I checked it a few days ago and the life indicator was blue. She turned right over. Glad I didn't buy a new one.
   / Longest Original Tractor Battery Life? #26
wearing a battery down seriously damages it, they are not designed to take that.. one day you'll notice it won't crank the engine anymore, even after charging..
   / Longest Original Tractor Battery Life? #27
I am getting some freebee almost new Ambulance Batteries that were apparently discharged too low, and now won't meet certification.
Age alone doesn't mean much without knowing hours, temperature and other conditions.
   / Longest Original Tractor Battery Life? #28
the bottom line is, they were damaged by discharging too low, and won't perform as a good battery would. also, make sure these are not deep cycle batteries. they are not designed for starting, and get damaged by a charging current that is too high, most vehicles would use a charge current that is way too high for deep cycle batteries..
   / Longest Original Tractor Battery Life? #29
Replaced original battery in my 2005 Montana last year. Have 3rd battery in my 2014 Silverado truck. Dealer says I don't drive it enough to keep battery charged. Also, seems to me you can't let these newer batteries die as they will not keep a charge after they have been completely discharged.
The best cars have the dimmer switch on the floor.
   / Longest Original Tractor Battery Life? #30
9th yer for my GC2410, certainly not the longest by any means but I am impressed. My 2005 Husqvarna batter was just replaced a couple years back which made that battery 13 years old.
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
205196 (A52706)
205196 (A52706)
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
