Kubota L175 Won't Start
   / Kubota L175 Won't Start #11
If you've got a voltmeter, check to see that you're getting voltage at the terminals of the glow plugs when holding the key to the left. Should be >5V at each glowplug. If you only get voltage at the first one (closest to the dash) or none then remove / clean / tighten the connection of the wires at the glow plugs, and while they're disconnected, check glow plug impedance with an ohmmeter between the terminal and ground and across the glow indicator (I don't remember what it should read, but definitely less than 10 ohms). The glow indicator is in series (in between) the keyswitch and the glowplugs. The glowplugs are all in parallel. If connections are loose the glow indicator on the dash won't glow or will glow very dimly, the glowplugs won't get hot enough and your engine won't start while cold, just crank and puff white "smoke" (unburned fuel).
   / Kubota L175 Won't Start #12
Suggest same procedure/solution.... Just late getting here to say it....
Dale
   / Kubota L175 Won't Start #13
Speaking from some experience from my life with the L260...
Only one of my glow plugs works, front one is open circuit and near onobtanium (I'll look to get one this spring/summer, but it starts for now, I have a link that says they have them). I usually crank a little bit to get fuel in the cylinders then use the glow plugs for a few seconds but it doesn't sound like that is your problem.
I have had fuel starvation problems a couple times, in the banjo bolt going into the primer pump the large bolt is a screen that likes to plug up. I've dealt with that twice. Another time my fuel tank actually plugged so I drained it and blew the chunks out with compressed air.
   / Kubota L175 Won't Start #14
Thanks for decoding the lights for me. I was only guessing what the light on the left was. There is a metal ring on the right next to the tachometer. Is that where the glow plug light should be? There is an empty hole and no light has ever come on that I have noticed.
It’s not a light per se. It’s a coil of wire that glows red when hot that should be under that metal ring. If there is no wire in there, that might be a problem. Pete’s says glow plug indicator is in series which I think means your glow plugs won’t work if the indicator is missing or loose. Electrical is not my thing though :p
   / Kubota L175 Won't Start #15
This is typical of what a glow plug indicator might be (comes in many different forms though)... As current flows through coil of wire to heat glow plugs it also heats coil of wire in indicator, its like a pilot lamp for a "on/off" switch... If unit is missing (if it originally had one) or damaged or glow plugs (all) have failed you will not get a glow indication that may be indicator of problem...
And if functioning properly may look similar to this...
Also found this circuit to help understand electrical function of glow plug circuit....
glowwiring-jpg.228533
You GP circuit may or may not have relay, or "magic timer" it may get power from ignition switch directly to glow plug indicator.... Lots of variations or possibility.... All which depend on tractor brand/model....
Dale
Thank you for all your help. I have 12 volts coming from the glow plug heater switch to the plugs and the plugs checked out bad. I hope I am good to go. Thanks for everything. I'll update after installing and trying the plugs.
Can you tell me why it is said the glow plugs are wired parallel when there is only one wire going to the first plug that is jumped to the second plug? IMG_8458.jpg
   / Kubota L175 Won't Start #18
Because its next to impossible to wire in series..... Series would be one after the other like those Christmas lights where one goes out and they all go out.....
Parallel mean they each get their power from a common buss and their ground from a common source (head of engine)...
The buss highlighted in yellow is what supplies power to second glow plug, this is what makes GP's in parallel....
Also maybe this graphic will make it clear...
Dale
   / Kubota L175 Won't Start #20
Dale
In that series of Kubota's: L175, L210, L225, L260 there is one orphan. The GP's on the L210 are wired in series.
This is the series GP which has two electrical terminals on each GP.
This photo is of series wired GP's which someone wired incorrectly
I suggest you start by photographing the GP's and associated wiring on your engine. Because there was one model in that series with series GP, I have found that "do it your self people," get things messed up.
Without properly operating GP's those engines are next to impossible to start.
For engines with parallel GP's, the cost per GP is minimal. The series ones are over $100.
If series GP's were installed by mistake they will not work.
Dave M7040
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
UNUSED PAIR OF FUTURE 72" FORK EXTENSIONS (A54757)
UNUSED PAIR OF...
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
New Hay Saver Horse Round Bale Feeder (A50775)
New Hay Saver...
