John Deere 1070 won't crank
   / John Deere 1070 won't crank #1
spook1
Willow Wood, Oh
Honda
I just used by 1070 2 days ago. Went out today and when turning the key on I hear a click and the dash lights come on but it won't do anything else. I crossed the terminals on the starter and it started up. Would the starter just go out after parking it? It looks like the starter and solenoid are all one unit. Is there anything else this could be? Hopefully something cheaper than a new starter. I don't know where to begin to look. Any help is appreciated.
   / John Deere 1070 won't crank #2
One of the safeties is on. PTO(s) on, still in gear, seat switch. Maybe something under the seat prevents it from starting. Although, if it started and stayed running it might not be a safety switch. My 1070 had a problem where the solenoid contacts wore out. $20 for new contacts for a Denso starter on ebay. Easy to change once the starter is pulled off the tractor.
   / John Deere 1070 won't crank #3
I'll 2nd faulty safety switch or pto control is engaged
Where it started and stayed running do you think it would be a safety switch still. I figured if it was a safety that it wouldn't run.
   / John Deere 1070 won't crank #5
Do you have a volt meter to use to start checking voltage?
Assume you can confirm that the PTO switch is off?
   / John Deere 1070 won't crank #6
YES most safety switches are in starting not running circuit. There are a few exceptions such as pto switch connected to seat switch
   / John Deere 1070 won't crank #7
Be sure to check the ground cable from the battery to the frame. My 1070 did the same thing and it ended up being that ground connection at the tractor. Cleaned it up and reassembled with dialectric grease and never had the problem again. It's like it had enough resistance to run glow plugs but not crank the starter.
End up being the PTO switch. I cleaned it up and it works like a charm. Thanks a million guys for your help.
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
SHOPBUILT PUSH BAR FOR FORKLIFT (A52708)
SHOPBUILT PUSH BAR...
Miller Millermatic CP/CC-1500 Industrial Welder  Heavy-Duty Power Source (A59225)
Miller Millermatic...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
Toro Sand Pro (A56859)
