Ck30 Hydraulic filter assembly
/ Ck30 Hydraulic filter assembly #1
sodamo
Super Star Member
Big Island, HI
Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Well, not good. Managed to break the hydraulic filter assembly on my CK30. Anyone replace before?
T2195-38111 seems to be the part number.
Also any ideas on possible bypass in order to get tractor in a more workable place?
/ Ck30 Hydraulic filter assembly #2
Are you talking about the filter mount for the HST filter? The one that has the filter hanging vertically on the right side or the tractor. If so, I remember a few members years ago advising that they either were in the woods and a branch caught it or had the bh frame pound it. It seemed like an easy replace. The hoses use banjo bolts with rubber o-rings and a couple bolts mount it to the tractor frame. I don't know of any way to connect the two hoses together to bypass the filter because they have those metal ring type ends.
/ Ck30 Hydraulic filter assembly #3
"No" on the by-pass with the HST Tractor (flow is split in the housing)....but....your Filter Assembly is shipping today !!
Team MIE
Yes, Victor, that’s the one. Sadly, I was aware, made mental note and worked about 2 hours before snagging it. Unfortunately not in a convenient place to work, slight slope, rough ground, tall grass. IMG_0198.JPG
Team MIE
Thanks so much for the prompt shipping.
Any hints on the replacement procedure?
/ Ck30 Hydraulic filter assembly #6
I copied this over here to your CK30 post;
Put your range transmission in neutral and start towing or dragging it.
You can jack up any loader if needed to get it off the ground or run a chain under a bucket to lift it when towing.
You may have physically move your steering if the steering valve/motor is out of oil, disconnecting the hydraulic cylinder will help there at times.
Some times you can actually remove that broken off piece in the center,
it may well be a close threaded nipple, many are.
Good Luck
Good Luck
Thanks Lou
Challenge may be lifting the bucket high enough to clear to get back to the gravel road, there is a small dip just before the rise.
Toying with thought that maybe there is way to seal off the housing to allow unfiltered flow for a short run. Hmmmm, maybe check the tupperware.
Broke off just above the threads.
/ Ck30 Hydraulic filter assembly #8
Here are the pictures of the skid plate I made to protect mine. I just knew it was only a matter of time especially while working around stumps and in the woods.
20160327_194827.jpg20160327_194833.jpg20160327_194912.jpg20160327_194922.jpg20160414_183630.jpg
20160420_180220.jpg20160420_180123_HDR.jpg20160420_180105.jpg20160414_183639.jpg20160420_180237.jpg
/ Ck30 Hydraulic filter assembly #9
Thanks Lou
If you can tow it forward, jack or lift the bucket upenough to get a chain under it and up to the tractor frame or grill guard, the other end up to the towing vehicle, the higher the better it will work your tow will help to lift the bucket.
The other way is to lift the loader with a jack or another bucket loader, then cut a couple of pieces of 2x4 or angle iron to lay on the boom lift cylinders and wedge against the cylinder laying on the piston rod and the frame of the loader.
At times when I'm working under a loader that does not have safety bars I lay angle iron pieces on the cylinder rods butted up against the cylinder and lower the boom down to them.
Very nice Jabelding.
Where you live in Maine? Born and raised. Most of my time south in Kittery, South Berwick, York Beach, but haven’t lived there since late 70’s.
Was able to get it up to firmer ground using long straps and chain with truck on the driveway for solid traction. Ground just too soft from the pig rootings. Then was able to tow it on to drive and back home inside the fence.
Took bucket off and enough tension with strap to keep quik attach off the ground.
Got the broken filter housing off, getting new one back on could be a challenge.
Seems maybe I should have ordered O rings, but only 1 shown. Anyone know O Ring specs?
Banjo bolt had no washers at all.
Broken housing
/ Ck30 Hydraulic filter assembly #13
Where you live in Maine? Born and raised. Most of my time south in Kittery, South Berwick, York Beach, but haven稚 lived there since late 70痴.
I am up in the Bangor area now but grew up in southern Maine near sebago.
Sadly, the parts didn’t arrive today. Hopefully Monday.
/ Ck30 Hydraulic filter assembly #15
I got mine badly bogged and in the effort of trying to get it out ,I used aluminium ramps that unfortunately managed to smash my housing off.
The worst part was lying on my back in the mud with oil everywhere fitting the new one on. I should have got a medal for that one.
Didn't help get the tractor out though. It still took a couple of weeks before I managed to free it.
Doesn’t sound like fun at all.
I have my parts, just need find time, hopefully early this week.
Hydraulic filter assembly installed, tractor back in operation.
Actually pretty easy to install by taking HST filter out, which I had planned to change anyway.
So 2 new hydro filters and about 7 gallons new fluid.
At bit harrowing for a bit, nothing worked. Fluid level was just below top mark. Air had burped out during fill, but perhaps some still trapped. Was beginning to think I had other problems like maybe the pump was toast. Took a break, perused the workshop manual, can’t say that was helpful in the least. When back up to tractor, checked level, started and then kept moving anything hydraulic - FEL, rear remotes, 3 point, steering, HST pedal (in neutral). Finally, while turning steering wheel and loader control same time a spark of life. Spent a couple minutes exercising everything, put it in M and drove it back to tractor shed. Seems to be working great.
Happy camper here 🤙
/ Ck30 Hydraulic filter assembly #18
Did you need anything else beside the mount and a new filter?
You might want to get new O rings. I was careful and mine were OK.
You’ll also need to refill your hydro fluid.
(2) Tractor Fenders (A64119)
(2) Tractor...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2005 Dodge Caravan Van (A61574)
2005 Dodge Caravan...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
