External Position Control Lever
/ External Position Control Lever #1
Avenger
North Idaho
LS XR4145C
As some of you know, my XR4145C did not come from the factory with the 3pt external position control lever. The dealer actually noticed this when he dropped it off new. He ordered the lever for me, but when I attempted to install it last fall, I noticed I was missing more than just the lever. I was missing the entire bracket that the lever system bolts to. Apparently LS deleted this feature from my tractor all together. Now I have the lever, I can make a bracket and weld it to the frame, but I am coming up with no idea on where to hook it into. I thought I did, then I saw a video on YouTube showing the back of another XR4100 and the linkage does not go to where I thought it did. But the video did not show a good detail view of the linkage, only the lever.
I could reach out to the dealership and have them come out and make it work. I can image that some custom fabrication on top of a service call would be cheap. OR I can do it myself. The 'fabrication' is very minimal, just need to know where to hook the stupid thing into.
I have gone to the dealership, but they do not have my tractor in stock.
If you have this lever on the XR41 series, could you please post a picture of it so I can see exactly where it hooks in? I am hoping I dont need to actually make anything more than a mounting bracket, but I could be wrong.
Thanks in advance!
/ External Position Control Lever #2
There is a feature that should be standard on all cabbed tractors, no matter what brand it is.
I've never owned a cabbed tractor but I can clearly imagine the pain of having to go inside the cab just to lift the 3 pt sometimes an inch or so.
/ External Position Control Lever #3
Mine is an XU series tractor, but I would think it should be similar.
It is a very simple setup. Both the handle and the part that the rod end connected to spin freely on the bolt. The little bracket bolts to a vertical tab welded to the cab.
To use the handle, you have to pull the handle out of its stowage point, then move it until it aligns with the hole in the quadrant that has the rod end attached to it. Then move the handle left against the spring tension to engage the hole and the move the lever up and down. When the three point is where you want it, you let the handle move to the right and disengage the quadrant, and stow the handle.
The rod end attaches to the same quadrant that the three point handle inside the cab does. Both move in unison. When you move the outside, the handle inside moves. When you move the handle inside, the rod to the rear lever moves, but moves independent of the handle in its stowed position.
While you are looking at the area in this picture, have someone move the three point control lever inside the cab, and you should see where the rod should attach.
I thank you so much! But unfortunately that is way different. Took me a second to figure out exactly what I was looking at. I really do appreciate it though!
/ External Position Control Lever #5
Yes! Just need to see the linkage inside, where it hooks in. Thank you!
/ External Position Control Lever #7
Does that whole handle move when you move the lever inside?
It looks like a solid connection at the handle.
/ External Position Control Lever #8
Next two from below:
Don’t know what all yours does and doesn’t have so I may have taken more pictures than you need.
/ External Position Control Lever #9
Here is how I did mine. IMG_20190316_155834.jpegIMG_20190316_155731.jpegIMG_20190316_155854.jpegIMG_20190316_155825.jpegIMG_20190316_155854.jpeg
Off of a 2018 XR4155HCView attachment 596002
View attachment 596003View attachment 596004
Perfect! Thank you so very much! That really helps!!
That's what I was looking at doing too. But it seems like that pin does not stick out far enough to get both linkages on there? Did you remake that pin? The control is backwards too, right?
I spoke with my dealer and informed him of my struggles. He is going to order that plate with with the tab that it is supposed to hook into. That tab or ear is missing from mine. Which is why I was confused. If it had been there, this would not be an issue. Hopefully wont take too long to get it and get it installed.
Thank you all again for the help. Once I get it done, I will post a picture.
/ External Position Control Lever #11
That's what I was looking at doing too. But it seems like that pin does not stick out far enough to get both linkages on there? Did you remake that pin? The control is backwards too, right?.
I had the bracket on the cab frame but I didn't have a separate ear for the linkage to connect to. So I ground the linkage down so it would fit to the existing pin without being too tight. Basically I replaced the washer with the linkage. The control could be backwards on mine due to the linkage being 180 out. When I lift the handle it raises the 3pt and down lowers the 3pt.
OH! well... that doesnt seem backwards at all! Up is up and down is down?! That might be better! Never thunk to grind the linkage down. Might have a look at that instead. I'll see what my dealer comes up with.
Thank you!
/ External Position Control Lever #13
Having only owned open station tractors - I was a tad confused. You are saying there is a 3-point position control lever inside the cab and another out back - right. That would even be handy for me. I have a small wire loop on the end of a rather long pole. The loop goes over my only position control lever - and sticks out back. I can push/pull the pole to activate the lever. Pretty crude but it works and saves a whole lot of time.
Yes, exactly. I thought my tractor came with an external lever, it did not, so I am (attempting to) adding it. This would give me a lever outside for hooking or unhooking equipment easier. With a cab tractor, to make any small adjustment means walking over to the right side door and reaching in to move the lever. Hopefully you moved it enough and/or not too much and in the right direction as you typically cannot see the 3pt standing there. Otherwise you need to climb up in the cab to make a small adjustment. This lever is an absolute must for cab tractors.
/ External Position Control Lever #15
Man - do I EVER know exactly what you mean. That is the one and only reason for my pole & loop. Even without a cab - the back/forth, repeat, etc is a real PITA.
/ External Position Control Lever #16
Thank you!
I looked when I got home and I am reversed, up is down and down is up. Not sure what I was thinking but it certainly works for me. I wouldn't be with out now.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
Topsoil Trommel (A57453)
Topsoil Trommel...
