Need to add two rear remotes to a John Deere 5300
   / Need to add two rear remotes to a John Deere 5300 #1
MMalabama
Thomasville, Alabama
Mahindra 4540
I have a friend who needs to add two rear remotes to the back of his John Deere 5300. We need to know where to tie into at on this model tractor, he said dealer wanted 2k to install them so I figured TBN could help us figure out how to do it. I have attached pictures showing the pump and the main line running to a block in the rear of the tractor. Im thinking this is the Pressure supply for the 3 point lift. Im assuming that these plugs on this block in the rear would be the proper place to add line(s) for the remotes. Just dont know which ones, they didn't seem to be labeled that I could see. There is no loader on this tractor, line goes straight from pump to this block that is mounted to the rear of the tractor sort of under the seat.
Is there anyone that an help with this one?
Dealer not an option. Can you put a double spool valve in line between pump and 3 point? Power Beyond would go to 3 point where would return to tank go? The tank?
   / Need to add two rear remotes to a John Deere 5300 #6
Dealer should have a schematic.
Your q isn’t that easy- you have no pressure regulation that I can see and the 3 point typically doesn’t get pressure regulated.
   / Need to add two rear remotes to a John Deere 5300 #7
Go to a JD dealer and look / pictures of any similar tractor with a loader. Pay attention to the add-on block. Or just get the loader hydraulic kit and slap it on. I use the loader connections for my rear remote needs.
Neither would a typical loader valve then that comes straight off the pump on any standard tractor with a factory loader, unless its built into the valve.
The whole point of this is to not pay JD 1500-2500 dollars to add rear remotes. JD mid mount valve is gonna run 1500 alone.
   / Need to add two rear remotes to a John Deere 5300 #10
Sounds like you’ve got this figured out. You’ve managed to argue with every person offering help. Good luck
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2021 Isuzu NRR (A50323)
2021 Isuzu NRR...
2004 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2004 STERLING...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2023 CFG QNT45 Mini Excavator (A49461)
2023 CFG QNT45...
