Good morning!!!!
   / Good morning!!!! #90,541
36 going to 55 and sun.
Rick, I didn't forget about National Nap Day...took a nice 15 minute one.
PJ, I like that clock. Every school should have one.
Well, I may have finally killed the John Deere mower yesterday. Since getting the zero turn, the Deere's job had been reduced to mulching leaves in the fall, and mowing the part of the side hill where I've left the yuccas to spread, and need something narrower to mow between them once or twice a year since the tractor and bush hog won't fit. Got the mowing about done, but each time coming up hill was slower...finally it would not back in reverse, and no longer had the transmission strength to come back up the hill. Maybe this morning after cooling off it will move. Otherwise, I'll take the tractor down to pull it back. 828 hours and 15 years, so got my money's worth on their 100 series lowest-end yard machine.
   / Good morning!!!! #90,542
24F now mid 30's for high dusting of snow over night.
E muffin feed the critters slow roll to work.
Enjoy the day all.
   / Good morning!!!! #90,543
Buckeye.
Sorry for the loss wife aunt...special thoughts prayers.
   / Good morning!!!! #90,544
poured first cup of coffee. 16° with clear skies this morning. Heading to 45° with lots of sun. Every place that still has snow is a sheet of ice. Very slippery. Still a slow melt. Which is good. Hope to get out to shop and get work done today. Head cold is hanging on. Need some fresh outside air. Wife OT are not fun visits. But hope that the Vital Stimulation Treatments (similar to Tens) are going to help in the long run.
Buckeye, sorry for your wife's Aunt's passing. May she RIP.
Sad about 2 college girls.
Don, watering brown grass makes it grow?
Wngsprd, maybe it needs a trans oil change.
PJ, neat clock.
Rick, nice wash job. No nap for me yesterday. Maybe I should take 2 today.
Kyle, several different math clocks on Amazon. None for me. I dropped my slide rule last year. It broke. Filed it away in the round basket. :D
Prayers for all.
Good Morning All.
   / Good morning!!!! #90,545
Good morning! 57 ˚F might rain today. I fertilized the yard grass yesterday after mowing it very short. It was the first time I used the rear bag on the EGO mower. The mailman delivered the new battery while I was mowing, I immediately put it in the 20 minute charger and it got broken in yesterday. Mowing the grass 2" shorter really cut down on the mowing battery life time.
Today and tomorrow are suppose to be wet days if not we have to move some dirt to the picnic area before we mulch it. I volunteered for an "easy" job for the new trail's grand opening at the end of the month but I don't know what it is.
Ron I don't know why they are watering the brown grass, but probably because they have fertilized and it hasn't rained in a while. They are trying for an early green-up.
I forgot to celebrate Nap Day also. :confused3:
   / Good morning!!!! #90,546
19 and going to a high of 32°F. Wind NW 11 mph. 40% chance of flurries.
Yesterday I plowed everybody out and got farther on the lane to the downed tree.
I also picked up a tool box to hold all the extra goodies for the chain saw.
The rain we had the other day put the kibosh on my using the ramp I built to the north field. The ramp was made of snow and got really soft. It wasn't all that wide to begin with, wheel track wide. My bad.
All you guys planting your seeds get to enjoy the bugs and snakes and such so much earlier than I do. I am happy for you all.
I need to plow again today.
Have a good day all.
   / Good morning!!!! #90,547
"Rick, I didn't forget about National Nap Day...took a nice 15 minute one."
No WNG .... I'm the dummy who forgot.
Maybe I'll take two today .... to make up?
Edit: Since so many of us missed / forgot about Nap Day yesterday ...... I make a motion that we promote WNG to TBN "National Nap Notifier" for next year. All in favor .....?
THE NAP YOU SAVE .... MAY BE YOUR OWN!
   / Good morning!!!! #90,548
Good Morning!!!! 50F @ 5:15AM. Partly cloudy. High 62F. Winds SE at 5 to 10 mph, becoming NW and increasing to 10 to 20 mph.
Got the front end of the van up high enough yesterday that it only lost a quart of fluid out of the transaxle when the output housing came off. That was the good news. There was so much goop on the sealing surface it took a porta-power to break it loose, but at least there was a tab to press against.:eek: The bad news is that the actuator shaft has no seal, nor an o-ring, to keep it from leaking. There's no counterbore to accept a seal, and no groove for an o-ring. I don't know if this thing was made on a Monday, or if it's just a bad design. The linkage that moves the splined coupler is held together with snap rings, another indicator it was designed to be cheaply made, and I'm probably going to replace it with a more robust one. More money down the drain, but I'd rather spend it now than have it come apart and take out a very expensive transaxle. Sent an email with photos off to the supplier, and it'll be interesting to hear what they have to say about it.
Sharpened four saw chains, then went out and cut a few rounds off a the big pine trunk. As it started getting dark the saw didn't want to idle, then it didn't want to start, and I think it's fouling plugs. I don't think it had much use before I got it, and now that it's getting broken in, it's probably time to tweak the idle settings, and maybe treat it to a new spark plug.
I like your idea of using a tool box for your chainsaw accessories, Bill. I'm using a cardboard box, which works well enough, but it's no fun rummaging around looking for this or that. Might have to go shopping at HF next time I'm in town...
One thing I did do that makes life a little easier is tape a magnet to the handle of the small No-Spill tank I use to fill the saw. I slip the chainsaw wrench through the handle and the magnet holds it in place. The tank is a lot bigger than the wrench, so now both are easier to find out in the weeds where I usually use the saws.
   / Good morning!!!! #90,549
67°F and very foggy here this morning. Forecast is for 76° and overcast today with 10% rain chance. Tomorrow .... 90%.
Yesterday .... it stayed foggy here, till well after lunch. Probably same today.
Still sneaking up on getting the entire rolling fleet washed, I have the 55 HP tractor and the F-350 yet to do. That seems like 3-5 days worth ..... right?
I'm really bummed about completely missing "National Nap Day". .
Hope everyone has an excellent day.
Prayers to all.
   / Good morning!!!! #90,550
Yep, I learned on my neighbor's yard that mowing taller grass doesn't change the engine sound. In other words, it never sounds like it laboring, as a gasoline engine will. But the heavier load really does shorten the battery charge time span. And the same is true for the string trimmer.
56 degrees with a pretty good mist here this morning, going for a high of 66. I just took my granddaughter and her little dog to a groomer to get the dog a haircut. When they call to say she's ready, I've got to take them home. This week is Spring Break for the schools around here, so our granddaughter and her little dog have been here since Saturday, and going home today.
2021 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
1R COLE PLANTER (A52708)
1R COLE PLANTER...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
3PT CULTIVATOR, 2" BAR (A52708)
3PT CULTIVATOR, 2"...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
WATER HEATER & ELKAY WATER FOUNTAIN (A58374)
WATER HEATER &...
